Transmission
Old Sep 13, 2013 | 11:01 PM
I would consider dropping the pan, and at least having a look at the governor pressure sensor and solenoid. See if it isn't gummed up. (common problem) Also give you a chance to see if there is anything untoward in your pan.... (metal shavings)
Changing the filter sure wouldn't hurt in any event.
Old Sep 14, 2013 | 07:27 PM
ReadRam's Avatar
ReadRam
Where did the line blow and why? Pressure problem going on...Mine blew at the coupler disconnect by radiator last winter. I drove about 5 blocks when noticed something was wrong. Reconnected and added fluid with no damage to transmission.
Old Sep 15, 2013 | 03:21 PM
seabass202's Avatar
seabass202
do you still have the in-line check valve, anti drain back thing installed? it's in the line by the coil under the hood. if that gets clogged it can cause all this.
