Camshaft question
Old Sep 26, 2013 | 01:28 PM
Originally Posted by xjarhead69
Can the cam be replaced without removing the distributor?
If he has to remove the distributor he will need to have fuel sync set by the dealer, or someone with the proper equipment.
Which can add to the cost of the cam if he doesn't have access to proper equipment.
Dave
No. Dist has to come out to change the cam. intake has to come off as well.
Old Sep 26, 2013 | 01:32 PM
merc225hp's Avatar
merc225hp
Change the cam and the fuel sync has to be done anyway, add about $80 thats what shops up here charge.
Old Sep 26, 2013 | 01:35 PM
merc225hp's Avatar
merc225hp
RnR said he was able to change the cam without removing the dizzy, me I just pull the dizzy and the oil pump gear shaft or intermediate shaft when installing a cam in these motors.
Old Sep 26, 2013 | 02:14 PM
I didn't think you could pull the last bearing surface past the dist drive gear.... sure doesn't look like it on my engine...... (on the skid... not the one in the truck. )
Old Sep 26, 2013 | 02:22 PM
merc225hp's Avatar
merc225hp
^^^ Nor did I, but I have never tried it.
Old Sep 26, 2013 | 07:15 PM
Happen to have a cam laying about? Have a look at the distributor drive gear, and the rearmost bearing. If that bearing isn't signifcantly smaller than the gear, gotta pull the drive to get the cam out. (posting a pic would be nice. )
Old Sep 26, 2013 | 07:34 PM
redneck_ram's Avatar
redneck_ram
i was able to pull the old cam out without removing the dizzy. however, i removed the dizzy afterwards, to make things easier for putting the new cam in.
Old Sep 27, 2013 | 07:50 AM
Blue Mopar01's Avatar
Blue Mopar01
I'm tossing ideas around, for now I'm just trying to get somethings straightened out on what I want to do...I think I won't replace the heads yet and re-use the old ones( I know not the best idea) but that'll give me cash for the cam and valve springs if I can spare it. That way down the road when I have more cash I'll replace the heads then which is a heck of a lot easier to replace than the cam. Thanks for everybody's input!
Old Sep 27, 2013 | 10:25 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by Wh1t3NuKle
How will you use the rig? What is your target outcome? e.g., hp/tq numbers, mpg, towing, multi use, toy use, etc.
You haven't shed any light on what you are going for, therefore, people can't give you recommendations with the rough budget you stated. Let's say you get a very aggressive camshaft, then you have to deal with tuning and streetability, assuming it will be street driven (DD?). Expected usage matters here. That is just an example. There are a good handful of people here that have done a camshaft swap and nothing ran right. Will mpg be a factor for you? Being in N. Dakota (if your profile is correct) does not require any emissions check. Good for you jerk. :P Those kinds of details would help in the responses here.
Originally Posted by Blue Mopar01
Ok gotcha...I'd like to do the cam swap now and not later when the motor is together but with cash restriction, unless something happens, I guess the 1.7's are the next closest thing. I'll wait and see what happens. Will those 1.7's mess with anything overall? I know they add more lift but i'm sure my teacher will argue with me on installing them since they aren't "stock"....
I don't remember the specifics but I'm sure Wild and/or Merc will share and I recall that going to higher lift also impacts the stock valve covers. Is it also recommended on doing RRs that pushrods be replaced?
Well, keep in mind that when you pull the heads, it is possible that you find cracking. Also, on the note of replacing valve springs, does that mean going to taller ones or just stock ones?
Note, as far as I know, I'm the only one that has replaced my camshaft and not needed fuel sync set. The reason is b/c I marked my distributor housing on the block to know exactly it's position prior to removal.
Old Sep 27, 2013 | 04:57 PM
80Adventurer150's Avatar
80Adventurer150
Yes, the 5.2 cam is different than 5.9. The 5.2 actually has a little more lift.
It's wise to replace the cam bearings if you do a swap, but not mandatory I guess. The problem is the rearmost cam bearing cannot be replaced without pulling the motor.
How is your motor running? After messing with a few 5.2s and 5.9s my personal rule is to never fudge with a perfectly good motor.
