Skyjacker 501 kit install questions
That **** didn't do squat. I just torched everything and hit most of it with the impact gun ;o) I am wasting money on soaking them.
Side note... project came to an abrupt end. Apparently I need special tools to remove the track arm from the frame and from what I gather, a tool to remove the pitman arm as well.
Glad I'm in the military... GF is checking with the tool crib at work as we speak ;o)
I'll likely give it a go in a bit if I don't hear back from the GF (also a perk, GF is military so have no issues going into the units tool crib!). I have all new parts to do the HD conversion, so not too worried about damage.
InfO.
Edit: Shoot. Tool crib was closed. Oh well, I'll shut it down for the day. Merc, I hit everything up with some oil
P I'll let it soak until I get the tools I need. I'm ripping down to Houlton, ME tomorrow (or Sat morning) to pick up some extra parts I ordered - so it'll likely sit until then! So far, stoked though.
LOL, well, I don't profess to be amazing at logic, but yours certainly sounds solid ;o)
InfO.
InfO.
While you are waiting on tools try to get the two lower cam bolts out. Try one at a time, remove the bolt all the way not just the nut. If you're lucky they won't be seized to the bushing in the control arm.
A pickle fork or ball joint seperator I think is like $16 at crappy tire, this will work on the track bar and the drag link to the pitman arm. As for the pitman arm puller don't cheap out on this tool wait for the tool crib to open up cause a good one is over $100.
..... nevermind my last words. You are correct, two hammers.
Now to find something to undo the bolt holding the pitman arm to the steering box.
I use two single-jack, three pound hammers. Hold one against one side of the joint you want to pop. (the part of the linkage that has the hole in it for the stud.) SMACK the other side HARD a couple times. They pop right out.
Edit: According to google... 1 5/16"
