1999 46RE with P0753 code
Old Nov 22, 2013 | 03:40 PM
bunker's Avatar
bunker
Default 1999 46RE with P0753 code
Im moving this thread here.
Problem no 1st or OD can shift manualy from 2nd then to 3rd to drive it. No OD while driving. Have to put into 2nd to take off.
Code P0753 on scanner.
what ive done so far.
1.Relay is new and tested good. getting 12volts to relay socket.
2. Tried testing pin 21 of the white plug (female) that goes to the tranny get nothing here. with truck off. Do i need to have truck running? and what am i looking for at pin 21 OHMS or volts? and how much of each?
3. took out relay and drove it. no change at all wouldnt this mean the problem is before the tranny?
Is there a way to test the solenoids outside the tranny? like at the white plug that goes to the PCM? i thought all the solenoid wiring went to the pcm via that white plug.
"Hey you" told me to check the red wire going to the 8 pin plug at tranny havnt done that yet. again no power,engine running,key on engine not running????
any ideas??
Old Nov 22, 2013 | 09:28 PM
Test for power at the trans with the engine running. See what ya get.
Old Nov 24, 2013 | 12:43 AM
bunker's Avatar
bunker
anybody know what pins to test on the OD solenoid and what the readings should be?
Old Nov 24, 2013 | 02:40 PM
PCM controls O/D solenoid by switching its ground on and off. If you test for power on it's control circuit, you should see 12 volts. (engine running) Same for TCC. They get power from the common 12 volt feed. (red wire on 8 pin connector.)
Old Nov 25, 2013 | 02:56 PM
bunker's Avatar
bunker
Default crazy stuff
HY im not getting 12v on the red wire at the 8 pin. im only getting 0.05 v engine running and in park.
on the socket where the relay goes I`m getting the following volts. (trk running)
86=0.09
87A=0
85=12v
87=0.04v
30=12v
Old Nov 25, 2013 | 04:16 PM
xjarhead69's Avatar
xjarhead69
Here is little lesson on what the pin number represents and good general understanding of how the relay functions.
http://www.therangerstation.com/tech...ry/relays.html
Dave
Old Nov 25, 2013 | 04:22 PM
xjarhead69's Avatar
xjarhead69
86=0.09
87A=0
85=12v
87=0.04v
30=12v
Ok little test, you could pull the relay out and run a jumper from 30 to 87 and see if that works.
Or you can try running a jumper from pin 85 to ground with the relay in and see if that works.
Have you tryed swapping another relay into its place?
Dave
Old Nov 25, 2013 | 10:24 PM
bunker's Avatar
bunker
Default relay
Dave
yes tried 3 different known good relays. ill try jumping 30/87 like you said. according to the wiring diagram 87 goes to the 8 pin plug on the tranny and should be 12v. and im only getting 0.04 then there something in the wiring. dam I hate wiring! thanks Dave
Old Nov 26, 2013 | 11:53 AM
bunker's Avatar
bunker
Default jumper worked
Dave you did it. the jumper between 30/87 worked. all coeds and lights went away and it drives normal. now the question is wheres my problem? is it in the PDC or somewhere before that im thinking under the PDC where all the wires go in?
Tom
Infantry Retired
Old Nov 26, 2013 | 12:40 PM
Probably one of the connectors for the relay is corroded, or loose. Have a look at 'em, and see what's up.
