Oops. Busted Coolant Temp Sensor....
Old Dec 19, 2013 | 11:51 AM
  #31
RaissiKitten's Avatar
RaissiKitten
The big pry bar I am using now I literally had myself hanging from. LOL!!! Taking a break, before I use Dynamite to get it off...
Old Dec 19, 2013 | 12:15 PM
  #32
That'll work.......
It really shouldn't hang on THAT tight..... not wedged under the valve covers by chance is it? (shouldn't do that either.)
Old Dec 19, 2013 | 01:23 PM
  #33
RaissiKitten
Nope, But I found something. I need an opinion. The back two bolts I thought someone forgot when they put the Plenum in, aren't missing. They ARE Broke!! After reading it here I figured, oh why not stick a screw driver in there and just check. Sure enough! So, since the manifold isn't threaded.. Would this stop it from coming off? I have the Shop coming down to give some assistance here..
  #34
Ham Bone's Avatar
Ham Bone
Is the fuel rail still on it?
Old Dec 19, 2013 | 01:24 PM
  #35
RaissiKitten
Yes, the fuel rail is still on, but the line is disconnected
Should I remove it?
Old Dec 19, 2013 | 01:27 PM
  #36
Ham Bone's Avatar
Ham Bone
Depending on how long they've been broke they could have rusted all to hell and got junked up.
I've seen some rust that looks stronger than a weld.
Old Dec 19, 2013 | 01:28 PM
  #37
RaissiKitten
Yikes.. Maybe if I soak them real good with some PB Blaster? Im not sure when this work was done.. The guy that owned it before me, only had it 2 months. (He does more buying and selling than driving)
Old Dec 19, 2013 | 01:30 PM
  #38
Ham Bone's Avatar
Ham Bone
Worth a short. How far down are they broke? If they are sticking up into the intake much they will fight you when you try to pry it. It will have have to come straight up to get off. No angles.
I hope that. Made sense
Old Dec 19, 2013 | 01:37 PM
  #39
RaissiKitten
It does.. They are just barely in the manifold. Going to soak it till the shop gets here..
Old Dec 19, 2013 | 02:43 PM
  #40
They will give you some trouble... but, the front of the manifold should still break loose, even with them in there. Just gonna have to lift the manifold straight up to get it off of them, without breaking them off....
Once you have the manifold out.... soak the bolts with PB Blaster, clamp some vice-grips on them, and wiggle back and forth, while tapping on the end of the bolt with a hammer. The vibration will get the pb to soak in better, and the bolts will break loose, and come out, as opposed to breaking off, and giving you even more headaches.
