Picking a cam for torque
Old Dec 19, 2013 | 01:43 PM
97r/tram's Avatar
97r/tram
I'm saying his money is better spent elsewhere if he doesn't plan on putting a whole top end one the engine.
Old Dec 19, 2013 | 02:30 PM
Ham Bone's Avatar
Ham Bone
This is true like swapping in 60s to get rid of their puny little 1500 axles
Old Dec 19, 2013 | 02:41 PM
97r/tram's Avatar
97r/tram
My puny's hold up just fine with 37's.
Old Dec 19, 2013 | 02:53 PM
merc225hp's Avatar
merc225hp
Fwiw the M1 goes great with just a set of rr's and a tune, been there done that and more. If you don't have an M1 don't speculate as to what it will and won't do, it needs some basic mods but not like you think.
Back on topic
OP
I have two sets of numbers for you
I believe this is to be for the 2000 year truck
Part Description : Camshaft
Opens : -13 BTC/33 BBC
Closes : 18 ABC/-17 ATC
Duration : 205/196
Opens : 15 BTC/61 BBC
Closes : 75 ABC/18 ATC
Duration : 270/259
CamLift : .265/.265
Gross Valve Lift : .420/.420
Center Line C/L : 112/116
Rocker Arm Ratio : 1.6/1.6
Valve Lash Clearance : HYD/HYD
And for the under 97 under all I have is .410 and .410
I will see what more I have on my pc for this info.
Old Dec 19, 2013 | 04:24 PM
ChillyPhil's Avatar
ChillyPhil
Where's a good set of heads at? What do they run?
You guys talk me into too much shi*t.
Old Dec 19, 2013 | 04:26 PM
Odessa/Clearwater offer both better than stock standard heads. (thicker castings, less prone to cracking.) and bigger valve heads (2.02 intake, 1.92? exhaust) for under a grand for the pair. The BTS replacements can be had for around 600.
Old Dec 19, 2013 | 04:56 PM
merc225hp's Avatar
merc225hp
More heads for you to look at.
http://stores.hi-potek.com/-strse-3....Categories.bok
And then there is this
http://www.performanceinjectionequip...te_Engine.html
Old Dec 19, 2013 | 06:09 PM
army_greywolf's Avatar
army_greywolf
To redneck ram: If I went with this cam I won't run HS 1.7s for sure as I don't have enough max lift. Kegger Mod, MAYBE I will clean it up a bit, knife edge the runner edges, bead blast and see what comes of it. I'd like to get a 40 ft lb bump...I feel the cam is the biggest issue with getting good numbers, my engine is healthy.
Now, I've done it once, reusing roller lifters...would it be ok to do so in this application? Mind you I am not revving beyond 4800 rpm ever.
Old Dec 19, 2013 | 10:57 PM
Yeah, not as much of an issue with rollers. Although, replacing them IS cheap insurance. I think you can get a set from ma mopar for around 120.00.
How many miles on the lifters you are considering reusing?
Old Dec 19, 2013 | 11:16 PM
army_greywolf
less than 120K, and they've lived a very good life, I hooked one out to look at it, looks brand new.
Right now, I'm planning cam, hughes plate, kegger mod, looking to replace a few sensors, the IAT is way out of calibration, pcm says 90 degrees when the probe in the vac port says 65... IR gun confirms the same, 65 degrees right on the sensor... so that will get changed, O2 sensor, probably timing chain, though correlation is still less than 4 degrees. I don't plan to change anything else. I may do head gaskets just so I can lift the heads off to look at condition and determine whether now is the time to go for EQ heads.
