p0037 heater circuit low post cat sensor
Old Dec 21, 2013 | 11:32 PM
redneck_ram's Avatar
redneck_ram
Default p0037 heater circuit low post cat sensor
well, replaced both o2s and im still getting p0037. i can clear the code, and it will pop up immidiately.
what could cause this? any way to fix it?
Old Dec 22, 2013 | 11:25 AM
Wiring issue. If you don't have it already, get the 01 service manual, and check out the wiring diagrams for the sensors. Sounds like you have a break somewhere.
Old Dec 22, 2013 | 02:14 PM
redneck_ram
Would make complete sense... clear the code at 9 this am and ive beeb idling for the last almost hour and its still off. Guess going a few months without a sensor made it go bonkers!
Old Dec 25, 2013 | 08:37 PM
redneck_ram
Looks like im going to be pulling the engine harness soon. Codes keep coming back... kinda lost on this one...
Old Dec 25, 2013 | 10:49 PM
merc225hp's Avatar
merc225hp
What pcm are you using I don't remember? The 5.2 and you had it flashed for the 5.9 or a 5.9 pcm that was flashed.
Old Dec 26, 2013 | 08:40 AM
redneck_ram
i have my original 5.2 pcm, and just used the sct to tune it for the 5.9
Old Dec 26, 2013 | 12:39 PM
merc225hp's Avatar
merc225hp
So I have a odd suggestion for you to try, put a 195 stat back in the motor, three other people have been chasing the same problem, they changed out parts just like you and it never solved their problem. I suggested to try the 195 stat and none of them have the codes back. If you have the 91 tune in the truck back it off to the base one when you put in the 195.
Sounds odd but worth a try and it's cheap and ez to do.
Old Dec 26, 2013 | 09:46 PM
redneck_ram
gonna pull the engine harness on my next day off, which is monday. ill look into frayed, or burnt through wires. hopeing its none of those. if it is, ill cut em, and splice in new wire. oh well, itll get fixed soon enough.
Old Oct 26, 2014 | 10:27 PM
redneck_ram
late reply, but i fixed the issue... ended up being a fuse!
