dome, bed light and mirrors
Old Dec 24, 2013 | 11:55 PM
bulldodgemoe's Avatar
bulldodgemoe
Default dome, bed light and mirrors
Dome light. Bed light and power mirrors dont work. No power to each. I have checked all fuses included the IOC fuse #12 slot. Even replaced fuse for the heck of it. Any solid ideas I can try. Have a feeling its a combined problem.
Old Dec 25, 2013 | 12:13 AM
bulldodgemoe
Side not radio works fine. Its not the stock radio.
Old Dec 25, 2013 | 12:50 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Check headlight switch. And door jamb switches.
Old Dec 25, 2013 | 05:18 AM
bulldodgemoe
the front center map lights work though. a lot of reading is that they are all combined with this IOC fuse slot #12. wondering if anything to do with the non stock radio, the way it was hooked up? but the radio does exactly what its suppose to do. also been thinking tonight i wonder if its the alarm thing i removed when i first got the truck, the open door/left lights on alarm?? awful big for just a buzzer. i removed that, wonder if it broke the circuit
Old Dec 25, 2013 | 12:46 PM
Pulled the buzzer out of the fuse block? Put it back, see what happens.
Old Dec 25, 2013 | 03:18 PM
bulldodgemoe
now that the kaos is gone from the house. i will put that back in to see what it does. its not at the fuse block its tucked way under that dash.
Old Dec 25, 2013 | 06:03 PM
~moparlove~'s Avatar
~moparlove~
IOD fuse. that fuse controls all of those things. had a few go out on my truck. its the fuse that incased in the yellow holder.
Old Dec 25, 2013 | 09:01 PM
bulldodgemoe
as you would have read i tried that already. thats not it.
radio works, vanity lights work, over head console works, glove box light works.
this IOC fuse also runs those items listed above. as it comes from that junction block that feeds 3 circuits. my issue comes from C7 (circuit #7)
then it leads down to joint connector #5
out of joint connector #5 it feeds 4 circuits.
the issue is circuit #13 this power feed feeds to the 4 things in common. where can i find this joint connector #5?
if you have the 2001 manual page 799 8W-12-14 diagram
but on a side, funny and very weird note. i placed the annoying as hell buzzer back in and guess what?? my effin intermittent wipers work now!! who would have thunked that?
