Drivers rear wheel came off on the highway..
Old Jan 8, 2014 | 06:55 PM
  #41
Nate_rs's Avatar
Nate_rs
Also since I lost my tire and wheel they'll have to be replaced. Will I be alright running a wheel with 5 inch backspacing on one side and one with 4.25 inch backspacing on the other?
On that note will I be able run a 305/70-16 tire on one side and a 285/75-16 on the other without damaging my diff or 4wd?
They show to be the same diameter on metric converters..
Thanks
Old Jan 8, 2014 | 06:56 PM
  #42
Nate_rs's Avatar
Nate_rs
It won't spray fluid everywhere.
Haha gotcha, thanks.
Old Jan 8, 2014 | 07:04 PM
  #43
Yeah, backspacing won't hurt you at all there. If both tires are the same diameter, that is all you really care about.
Old Jan 8, 2014 | 07:10 PM
  #44
Nate_rs's Avatar
Nate_rs
Cool, thanks. Is there a margin there? Like one tire might be a tenth or two of an inch shorter than the other should it be fine?
Old Jan 8, 2014 | 07:12 PM
  #45
Nate_rs's Avatar
Nate_rs
Thanks
Old Jan 8, 2014 | 07:13 PM
  #46
Yeah, I don't think you could find any two tires, even of the exact same brand/type, that were exactly the same size, once inflated. Hell, even 3 pounds of pressure difference can change diameters enough to **** off various traction control systems.
Old Jan 8, 2014 | 07:31 PM
  #47
Nate_rs's Avatar
Nate_rs
Haha yeah I figured it shouldn't matter too much at such a small level
Old Jan 8, 2014 | 07:37 PM
  #48
Nate_rs's Avatar
Nate_rs
I was going to buy a rim but, could I run a tire that size on the spare rim that comes with these trucks?
Old Jan 8, 2014 | 07:40 PM
  #49
So long as the spare rim is the correct diameter, sure.
Old Jan 8, 2014 | 07:41 PM
  #50
Nate_rs's Avatar
Nate_rs
Okay cool.
