please help! transmission problem
I have a 98 dodge ram 1500 2wd with the 5.2. The truck works fine in reverse. if i put it in drive it wont move. put it in second and wont move. put it in first and its perfect then shift through the gears manually and its perfect shifts to over drive and drives great. when i come to a stop again i have to put it back in first and go through the gears manually again. only when i stop though. i already replaced the filter and govoner press solenoid and transducer. No check engine light on either. please any i deas would be great
Will your truck start in gear?
Have you checked for codes with a reader? Not all trans codes will turn on the CEL.
Might need to put some gauges on it, and see what's going on with pressures.... Since it shifts fine manually..... I suspect an electronic problem, more than something mechanical.
Trending Topics
Found out something else. i can pull the trans fuse under the hood and the truck will move when put in drive but its not in first gear. When you stop the truck it will die when the fuse is out though. put the fuse back in and it goes back to having to put it back down into first to get it to move. any thoughts on this?
on
If you able to shift the transmission thru the gears starting from low gear and upshift from1st to 2nd and the 3rd. You may have a governor and transducer problem. The transmission maybe starting off in a high gear and not 1st. Now if you weren't able to upshift thru any gears, then you would replace the valve body assy. I know you already replace the governor and transducer. But did you use Mopar parts?
