my truck is sucking oil into the cab
so the other day i was driving and noticed the windshield was milky so i turned the defroster on and nothing happened,so i tried the windshield whippers and still nothing.My father which was in the passenger seat at the time looked down and a small black pipe looking thing at the bottom of them dash and on the floor,he stuck is fingers in it and noticed it was full of fresh oil. he whipped it out with a paper towel and then the window unfogged does any one know what could be causing this problem???
well i read a couple things saying that in could be the intake manifold gaskets causing it, but i replaced that a couple weeks ago. like i said the oil is in this small black pipe at the bottom of the dash, but i just cant figure out why or how and i as i know off i don't have a mechanical pressure gauge
Check the rear seal on the intake. (yeah, I know, fun fun.....) It *might* be blowing around and making its way in thru the heater air intake. (or, you could just drop the blower motor, and see if there is oil in there..... only three screws, and an electrical connector. easier to get to as well...)
Is the seal at the back of the hood on the cowl still in place?
^ Going to be checking on that next. ( blower motor )
Not a 2nd gen...but looks like similar symptoms. They are saying bad heater core. The only thing is I know it's not coolant coming out of that vent. Which is what they are also saying would be the cause that condensation on the window.
https://dodgeforum.com/forum/3rd-gen...-question.html
Trending Topics
^ That is what i was thinking. It might be a small enough leaks and since you are not paying attention to the ac system it could be doing that to you. Dont forget when you turn your defrosters on the a/c system cycles to dehumidify.
^ We replaced the plenum gasket at the end of Dec. That's what I thought was the problem first. Little background info. We bought it about a year ago, and noticed this issue pretty soon. The truck doesn't get driven much right now. (Waiting on my son to get his license) I thought the plenum gasket fixed the problem, but when I drove it yesterday, the problem had come back. Probably less than 100 mile have been put on the truck since the repair. I don't want to think I messed up the repair, but I suppose it's possible. Just looking for other possible culprits before we tear the engine apart again.
