Need Switched Power Source in Engine Compartment
Old Feb 6, 2014 | 02:13 PM
renardk764's Avatar
renardk764
Default Need Switched Power Source in Engine Compartment
Any good pointers? Trying to avoid running a wire from the front of the truck into the cab through the dash, etc.
Old Feb 6, 2014 | 02:47 PM
Theres a couple going to the PCM, but, I would be hesitant to tap into those. Coil power is switched, but, goes thru the ASD relay. (engine would have to be running.) Grab the 01 service manual if you don't already have it, and go exploring thru the wiring diagrams.
Old Feb 6, 2014 | 03:23 PM
Sooper's Avatar
Sooper
Check the fuse / relay box by the battery. Sometimes manufacturers will actually leave a few switched and constant terminal that you can tap into for power.
I have not checked mine personally, but in the past I have found some.
Old Feb 6, 2014 | 03:29 PM
renardk764's Avatar
renardk764
I'll see what I can find and I'm hesitant to tap into the PCM also. :-)
Old Feb 6, 2014 | 03:30 PM
renardk764's Avatar
renardk764
I checked there but couldn't find anything that wasn't always hot. Thanks!
Old Feb 6, 2014 | 09:18 PM
Spillage's Avatar
Spillage
Do you have ABS?
I tapped one off there on my 98.
Just probe the back of the connector.
Old Feb 7, 2014 | 12:12 AM
95Twenty500's Avatar
95Twenty500
I use the 12v running to the cigarette lighter, it only gets power when the truck is on, at least in my 95 it does.
Old Feb 7, 2014 | 06:14 AM
renardk764's Avatar
renardk764
Originally Posted by Spillage
Do you have ABS?
I have ABS. And that will be perfect! Thanks
Old Feb 7, 2014 | 07:04 PM
Spillage's Avatar
Spillage
98 RAM (Details, right end of the post header).
Front (large) connector, 4th wire from the left on the top row.
Red w/Blue trace... 12V Ign 'on'.
