Parts List help!
Old Feb 14, 2014 | 04:58 PM
Matt Nickerson's Avatar
Matt Nickerson
buying direct from harland sharp is the cheapest..
Old Feb 14, 2014 | 05:08 PM
army_greywolf's Avatar
army_greywolf
You are looking for the minimum installed height.
Old Feb 14, 2014 | 05:15 PM
merc225hp's Avatar
merc225hp
You could go with these two part numbers and have adjustable rr's for about the same price. But you would need taller valve covers or remove the baffle from the stock steel ones.
Crane Rocker Arm Guideplate Conversion Kits 36655-16 $135
Crane Energizer Roller Rocker Arms 11746-16 $240
Old Feb 14, 2014 | 05:17 PM
You aren't going to get the lopey idle with a cam designed for low-end. Lope comes from huge duration cams, that don't develop a lot of vacuum at idle..... low-end cams will give ya good vacuum.
Look for like an RV/Towing cam. Stock springs, max lift is .480 inch. If you go more than that, you will need bigger springs. Keep in mind, most cams state lift numbers with stock rocker ratios. If you go to a higher ratio rocker, need to keep that in mind when looking at your valve springs.
You are looking for a cam that has it's power range in the idle-800 or so, to 4500-5000 RPM. Will be a nice power boost, but, may also require custom tuning.
Old Feb 14, 2014 | 07:26 PM
ProjectTwinTurbo's Avatar
ProjectTwinTurbo
Thanks! Big helps! Here's my plans
HEADS
-big springs
-port polish
-rocker arms
MOTOR
-cam
-modified kegger(may upgrade later on)
-sct tune. AFTER all the parts are bought.
-maybe KB pistons
-get the block+crank cleaned.
-high volume oil pump
That's basically it. But are valve springs like universal? Dumb question but I wanna now ha thanks
Old Feb 14, 2014 | 10:37 PM
When you pick out your cam, they will generally have recommendations for valve springs to match it. Get the ones they recommend. (chatting with someone on the phone to purchase your cam, is a REALLY good idea. Then, post the results here, and get OUR opinion on it. )
Old Feb 14, 2014 | 11:58 PM
ProjectTwinTurbo
Thanks a lot!!! I'll get the rest of it together and come back if I have any problems. I'm painting the truck first then gna start in the motor.
Old Feb 15, 2014 | 10:55 AM
Should do the mechanical work first, then you won't be as concerned about screwing up the nice, new, paint job.
I always hated it when folks would bring cars into the shop for major driveline work, and open with the statement: "I just paid X thousands of dollars to have it painted.".....
Old Feb 15, 2014 | 01:34 PM
ProjectTwinTurbo
Ha yeah bad thing is though b4 I made plans to build the motor I already started on body work.... So it's kinda mix matched right now.
I can across a question. It say our studs for the rockers are 3/8. And like above the 1.7 rockers are 5/16. How does that work? Thanks!
Old Feb 15, 2014 | 01:52 PM
merc225hp's Avatar
merc225hp
It's a stepped stud, one size on each end.
