Parts List help!
Old Feb 15, 2014 | 04:10 PM
  #31
ProjectTwinTurbo's Avatar
ProjectTwinTurbo
We'll. what's the benefits of having adjustable ones? Like when do u need to adjust?
Old Feb 15, 2014 | 04:25 PM
  #32
ProjectTwinTurbo
Also it would be big BIG! Help if someone can help me out on summit ravings website, I found the stud rockers. But I can't find the conversion kit thing for them
  #33
ProjectTwinTurbo
Also it would be big BIG! Help if someone can help me out on summit ravings website, I found the stud rockers. But I can't find the conversion kit thing for them. And I'm thinking I'm going with adjustable Bc it's just a little more $.
Old Feb 15, 2014 | 04:30 PM
  #34
merc225hp's Avatar
merc225hp
I check/adjust mine once a year in the spring.
http://www.summitracing.com/parts/crn-36655-16
Old Feb 15, 2014 | 04:32 PM
  #35
ProjectTwinTurbo
Did u have to buy anything else when u bought the adjustable RR? Like pushrods or anything?
Old Feb 15, 2014 | 04:53 PM
  #36
merc225hp's Avatar
merc225hp
You will have to add pushrods to your list, hardened. No the Mopar kit comes with everything in it, this is the kit I used. In my earlier post about this I had mentioned you need taller VC's or to remove the baffle from the stock VC if you go adjustable RR's.
Mopar performance kit part number is P5007404 price ranges from $500 up depends on the web site or your cost at the Dodge/Mopar dealer.
Old Feb 15, 2014 | 05:18 PM
  #37
ProjectTwinTurbo
Stock height? And wouldn't I have to go with 5/16? Instead of 3/8?
Old Feb 15, 2014 | 08:24 PM
  #38
Stock studs (I think) are 3/8ths screwing into the head, and 5/16ths where the rocker goes on. If you get straight up 3/8ths studs, you will want rockers to match. (and the thicker studs give more accurate valve timing, thus, more power.)
Old Feb 15, 2014 | 09:57 PM
  #39
ProjectTwinTurbo
http://m.summitracing.com/parts/scc-scp1022bl
I found these rockers. There's a video on YouTube of a guy putting them on his 5.9 Cherokee and he says they fit. And not only that they're cheap!
Old Feb 15, 2014 | 11:35 PM
  #40
merc225hp's Avatar
merc225hp
Post deleted
