95 2500 rear axle help
im sure this has already been posted, but im having a massive brain fart. i have a 95 2500 360 and i dont know anything about my rear axle. im looking into getting air lockers, so ive tried looking it up.... im getting mixed results, do i have a chrysler 9.25 axle or a dana 60? and because its a daily driver (for now) i dont want to take an axle out to count the splines, is there any other way to tell?
i have, what might be a stupid, question. However, i tried a vin look up and it says my 2500 is a light duty, but i have the 360(5.9).... is this correct and only the v10 and diesel are heavy duty, or is mine the heavy duty as well
shoot.... I had hope you wouldn't say that...... I do have a LD :/ cant find an air locker for it. how about the splines, do I have to count them?
thanks... I didn't find anything as to how many splines I have.... I still have not found a selectable locker for my rear axle, has anyone tried using a limited slip on the rear and an air locker on the front? as long as my gear ratios are the same this should work, right?
Trending Topics
Yep. Should work just fine. There are a selection of limited slips for the rear, front should be D44, LOTS available for that...
31 spline appears to be the general consensus. Even for the 3/4 ton.
