new!! help me 4x4!
Old Feb 24, 2014 | 08:39 PM
tyler22's Avatar
tyler22
Default new!! help me 4x4!
I'm new to this site and 4x4 but just bought a 2000dodge ram 1500 Laramie and 4x4 not working.I have a shifter on floor with 4 lo neutral 2hi and 4hi.it will let me push the shifter forward into 4lo anytime but nothing changes.cannot pull shifter back past neutral anytime.. tryed rolling in neutral reverse etc.can someone please explain what to trouble shoot or how 4x4 works on this vehicle. Also It kinda drives like I am in 4 wheel and can't go over 70. And when I accelerate my air stops blowing. Please helppppp
Old Feb 24, 2014 | 08:40 PM
tyler22's Avatar
tyler22
2000 4x4 transfer case new
Old Feb 24, 2014 | 09:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
I'm going to move your post to the 2nd gen ram section. You will get more response there, they the new member section.
Old Feb 24, 2014 | 09:25 PM
tyler22's Avatar
tyler22
thx dk what Im doin
Old Feb 24, 2014 | 09:52 PM
To shift into/out of 4lo, you must be moving less then 3 mph, and NOT be on the gas. (driveline unloaded.) If that doesn't want to work, stop, put the trans in neutral, and shut off the engine. Then shift back into hi range.
You should be able to shift into/out of 4hi pretty much whenever you want. (within reason...... like, below 55 mph.....)
Do NOT use 4x4 (any range.) on dry pavement. You will break stuff.
Should be a lite in the dash that indicates the front axle is locked. Is that coming on?
Old Feb 24, 2014 | 10:03 PM
tyler22's Avatar
tyler22
It lets me shift into 4 lo at any time even in park or moving.. the front propeller shaft is moving with the drive shaft when the shifter is either in 2 hi or neutral can't tell.
And it wasent till I bought the truck I noticed that someone taped over all the in dash lights on inside of cluster so I can't see them
Old Feb 24, 2014 | 10:09 PM
tyler22's Avatar
tyler22
And to clarify when I say it lets me shift into 4lo I mean the shifter goes to the 4 lo spot but nothing changes driving
Old Feb 24, 2014 | 10:21 PM
That's not a good sign.
There should be a NOTICEABLE difference in engine speed vs. road speed in 4 lo. If it doesn't grind, or make other odd noises, then it probably simply isn't working.
Pull the tape off the dash, and see what lites are on. The front axle may be locking in, but, I suspect the t-case is not.
You may have multiple problems going on there. Have a read of the plenum sticky at the top of this forum as well. My guess is, that's a contributing factor to only being able to go about 70.
Old Feb 24, 2014 | 10:50 PM
tyler22's Avatar
tyler22
Thanks ill try and do some more research and read around and post again
Old Feb 25, 2014 | 05:03 PM
Rescue35's Avatar
Rescue35
Get under the truck and check the linkagefrom the shifter to the tcase. Have someone operate the shifter and see what happens.
