Where does that vacuum line go? Truck idles extremely high, could this be the cause?
It's certainly a cause of a high idle, and it's also probably leaning out the mixture. I'm not sure what would normally go there, but in the meantime, put a cap over it, until you find the proper connection.
That conection may feed the vacuum line that handles the vent ducts on the inside of the truck. Connection may go from there back towards the firewall.
