2nd gen 4x4 upper and lower ball joint problems
Old 04-16-2014, 09:31 PM
bunker's Avatar
bunker
bunker is offline
Default 2nd gen 4x4 upper and lower ball joint problems
my front end guy is trying to put new lower and upper ball joints on my ram but is running into problems. He says the lower bj isn't seating like it should, he says the problem is when you turn the wheel the nut turns also as it should (thats normal) but his problem is that the ball joint shaft itself doesn't turn and should he says it is seated as far as it will go. he called a 28 year front end friend over for help and they both gave up. I got the parts from advanced auto (there brand) does anyone have a clue whats going wrong here?
Old 04-16-2014, 09:37 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Ball joint bolt?
Old 04-16-2014, 10:18 PM
bunker's Avatar
bunker
bunker is offline
the ball joint shaft the part the nut screws to
Old 04-16-2014, 10:49 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
h3lzsn1p3r is offline
you didn't buy moog there's your fist problem. the balljoint clearly has a larger taper than spec so its a faulty joint
Old 04-16-2014, 10:56 PM
bunker's Avatar
bunker
bunker is offline
yep I see that now and just ordered moog parts. lesson learned, there is some parts you cant just buy the cheap stuff.
Old 04-17-2014, 08:50 AM
stewie01's Avatar
stewie01
stewie01 is offline
Rumor had it that Moog's quality was going down hill.....
Old 04-17-2014, 03:25 PM
gnelson49's Avatar
gnelson49
gnelson49 is offline
Put all Moog ball joints and tie rods in my dakota about 4 years ago and have had zero issues. Alignment has been spot on and zero play in the front end. Spend the extra and go Moog, they can be found online cheap if you do a little searching.
Old 04-17-2014, 04:10 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Get moog problem solver series. I just rebuilt everything in a Dana 60 with them. Great quailty. Greasable. And made in USA
I can't speak for their other lines
Old 04-17-2014, 10:05 PM
bunker's Avatar
bunker
bunker is offline
Default moooooog
I ordered moog stuff should have it Friday. hope this fix`s it. thanks for the reply's will keep ya`ll updated
Old 04-18-2014, 08:35 AM
h3lzsn1p3r's Avatar
h3lzsn1p3r
at our shop we never like to install anything but moog. i have installed parts store brands they never get more than 3 months anyway. moog is lifetime if greased at every oil change.
Quick Reply: 2nd gen 4x4 upper and lower ball joint problems
