sluggish acceleration?
Old Apr 29, 2014 | 04:39 PM
  #21
dman12323's Avatar
dman12323
Went to oriellys and use there scan tool, came up with code P0740 Generic "Torque Convertor clutch solenoid circuit" let me confirm that again though. And the tranny fluid is kinda low let me go recall though
Old Apr 29, 2014 | 09:35 PM
  #22
ReadRam's Avatar
ReadRam
Originally Posted by dman12323
Ok ill have a shop do a pressure test, this is what my o2 sensor looks like. Also after I took out the sensor my rpms lowered back to 1.5k before shifting
Mine usually shifts around 1800 to 2000 rpm's, normal driving. That can vary a bit, depending on TV cable adjustment, and of course low fluid level, or a whacked out torque converter.
Old Apr 30, 2014 | 01:12 AM
  #23
dman12323's Avatar
dman12323
^Yep you nailed right on it.Code P0740 Generic was found out to be a near broken transmission torque converter. I filled the transmission with about 1/3 a quart of oil and the tranny went back to normal. Then I went on the highway and hit 75mph for a test run and the tranny heated up so quick o/d turned off and the red "tran temp" light came on. After the test run the tranny went back to its old ways of not accelerating until 25mph and it felt really boggy. Eventually the tranny cooled and slowly went back to normal. For some reason the radiator is not cooling the tranny fluid and im dumb founded about why it isnt cooling. The tranny oil is almost watery and gray and smells burnt so im sure the damage is already done right? One of the things I noticed was the lower check valve line was extremely hot.
Old Apr 30, 2014 | 10:07 AM
  #24
Is the check valve still there? If it is, that's a big part of your problem.
Old Apr 30, 2014 | 10:14 AM
  #25
dman12323's Avatar
dman12323
Yah its still there im going to remove it today after work. Im guessing im still gonna need a new trans rebuild though cause of the dirty watery oil.
Old Apr 30, 2014 | 10:19 AM
  #26
Ham Bone's Avatar
Ham Bone
GO BIG OR GO HOME
http://www.transmissioncenter.net/dodge.htm
Old Apr 30, 2014 | 07:14 PM
  #27
dman12323's Avatar
dman12323
Yep uplled the pan metal shaving everywhere looks like a new or rebuilt tranny for me. Thanks for the help guys! Im sure my 33's are kinda what helped the transmission fry itself alive.
Old Apr 30, 2014 | 11:47 PM
  #28
dman12323's Avatar
dman12323
Opinon - would you guys buy a used transmission with 166,000 miles?
Old May 1, 2014 | 09:50 AM
  #29
Adobedude's Avatar
Adobedude
No....166k on a 46RE is lot of miles.
Get yours rebuilt locally.
Old May 1, 2014 | 10:10 AM
  #30
i4got68's Avatar
i4got68
In my 98, the tranny was rebuilt I'm 08, so my truck now has 180k, so I'm assuming that the rebuild has roughly 60-70k on it.
