intake manifold removal help
Old Jul 8, 2014 | 12:50 PM
  #21
Arde's Avatar
Arde
Originally Posted by AtomicDog
So long as one doesn't go crazy with using a wire wheel on the head bolt, there are no issues with the practice. I've done it, along with running a die across the threads to ensure they are clean and have had no issue with either practice. I also run a tap into the block's head bolt threads to ensure they are clean, too.
Yeah, that's the sensible way to do it. IIRC, the explanation was that a wire wheel can spread the threads on the bolt. I've done it myself and never had a problem, that's why I was wondering about that particular piece of advice.
Old Jul 8, 2014 | 02:39 PM
  #22
Given that the threads on the bolts are FAR harder than the wires on the brush...... and it is simply not possible to get anything hot enough to matter..... I think that one falls definitely into the "Myth" category. Far more likely for severely rusted bolts to become sloppy once you clean all the rust off.......
