ECT shorted out now no spark
Old Jul 27, 2014 | 02:03 PM
95_dodgeram1500_5.2's Avatar
95_dodgeram1500_5.2
Guys at the parts store were wrong. Up until 98, there were two temp sensors. The single wire sensor was for the gauge. Two wire was for the PCM. If you applied 12 volts to the wrong wire on that sensor connector, there is a good chance you smoked the PCM. (it only runs five volts on that sensor, I do believe.)
Are you getting spark while cranking?
I changed the 2 wire sensor, and when my guage still didn't work I unplugged it and hooked a wire to the red side and meant to touch it to the neg terminal but accidently hit the pos instead, I work 3rd and it was lack of sleep I should had done it when I was rested up and fresh minded....how much is a pcm and what about installing don't you have to have them programmed, this sounds like alot of money, I've changed the ingition coil, distribor & rotor button, but I'm still not getting any spark
Old Jul 27, 2014 | 03:10 PM
You *might* be able to just order one from the parts store. Should run around 250 or so. Or, you could try and find a Mopar Performance PCM, slightly meaner programming... but, I think it wants you to use premium gas.....
95 isn't programmable, at least, not easily. If you can find one from a junkyard that has the same engine/trans as yours, (4x4 doesn't matter, PCM doesn't care) from a 94-95, should work as well. (and would be a good test just to verify the PCM is indeed the problem. Which, I suspect, it is.....)
Old Jul 27, 2014 | 04:29 PM
95_dodgeram1500_5.2
what about my voltage regulator I'm getting power to my plug on the coil but is not going going through the coil, just a thought
Old Jul 27, 2014 | 07:15 PM
You should only have power at the coil for about 3 seconds when you initially turn the key, then it should go away. If you see power on the ground side of the coil during that three seconds, then coil is probably good. (since it is new, that's an assumption, wouldn't be the first time I got a bad part right out of the box.)
My guess is, that backfeeding 12 volts thru a 5 volt circuit on the PCM roasted some control circuits.... Does the check engine lite come on when you turn the ignition on?
Old Jul 27, 2014 | 07:31 PM
95_dodgeram1500_5.2
Yes the check engine light comes on when the ignition is on, it has been on since I bought the truck 6 months ago, I tried the ON-OFF-ON-OFF-ON and it blinks but I can't figure out the codes I beleive it is throwing several and I have the table from troubleshootmycar.com
Old Jul 27, 2014 | 08:04 PM
Can you come up with a cheapy scanner, and have a chat with the PCM? Would be interesting to see what IT thinks is going on.
Old Jul 28, 2014 | 11:38 AM
95_dodgeram1500_5.2
With the way I hooked it up whats the chances that I did fry my PCM?
Old Jul 28, 2014 | 12:02 PM
95_dodgeram1500_5.2
I found a used PCM from a 95 318 auto for $50 from a junk yard
Old Jul 28, 2014 | 12:15 PM
Give it a shot.
Old Jul 29, 2014 | 09:55 AM
95_dodgeram1500_5.2
Sorry it took awhile to get a picture but here it is, the sensor to the far left in the picture is also a 2 wire sensor as well
