new intake installed!!
Old Aug 10, 2014 | 08:43 PM
M&O Performance's Avatar
M&O Performance
Default new intake installed!!
well i got my hughes intake in now and the truck is somewhat back to life!!
my old intake literally had a oil lake in the bottom of it.
i installed the IAT into one of the many vacuum ports the intake had and the one that runs into the side of the manifold with the 3 way connector has a open spot going towards the back of the motor on the passenger side. any idea where this would run to?
truck still has a rough idle around 5-6 hundred and is pretty boggy.
all new wires, ngk platinum plugs because they didnt have champions.... dist cap and rotor. and IAT sensor is new. maybe throttle body sensors, cam or crank sensor? and maybe that vacuum line could be my troubles?
going to cut cat off tomorrow and replace with a muffler. any suggestions?
Old Aug 10, 2014 | 11:09 PM
Ram Driver's Avatar
Ram Driver
You don`t want the IAT in a vacuum port, it needs to be were it can read the incoming air going through the throttle body. I would suggest you find a better place to install it.
Old Aug 10, 2014 | 11:18 PM
M&O Performance
[QUOTE=Ram Driver;3188298]You don`t want the IAT in a vacuum port, it needs to be were it can read the incoming air going through the throttle body. I would suggest you find a better place to install it.
okay thanks for the info! ill put it into the intake tube like the instructions say too. i was just assumeing that would be fine in a port since it is on the keg intake.
Old Aug 11, 2014 | 10:00 AM
[QUOTE=M&O Performance;3188300]
On the kegger, the sensor reaches into one of the runners, so it gets a pretty direct read of air temp.
Old Aug 11, 2014 | 01:53 PM
CSDavies26's Avatar
CSDavies26
Have your O2 sensors been replaced recently? They can cause issues at idle...try unplugging them and see if your idling issue is resolved. I also have the hughes intake....its an excellent product. I also happened to have a K&N cold air intake that provided the perfect place for me to place the IAT sensor. I didn't even have to extend the wires!
Old Aug 11, 2014 | 03:09 PM
M&O Performance
check engine light went out and the truck has no more idle problems! it seems doggy still though. this week ill be cutting the cat and seeing if that helps at all. replacing with a glasspack hopefully.
Old Aug 11, 2014 | 04:30 PM
CSDavies26's Avatar
CSDavies26
So you didn't change anything and the light went out on its own? I wouldn't hold my breath on it being fixed permanently. Get rid of the cat and make sure your O2 sensors are in good shape...just for future reference, our trucks prefer copper plugs...i just use the regular ol plain jane autolite coppers. Truck runs great.
Old Aug 11, 2014 | 05:42 PM
Yeah, sometimes the rare-earth plugs cause more trouble than they are really worth.
Old Aug 11, 2014 | 09:17 PM
Ram Driver's Avatar
Ram Driver
As everyone keeps telling you, you need to replace the 02 sensors, especially if there original with over 70,000 miles on them. You should also consider replacing the crank shaft position sensor. These sensors wear out over time and can cause issues. They don`t always throw a code when they go bad, but can cause a rough idle or engine miss.
Old Aug 12, 2014 | 07:24 AM
M&O Performance
Awesome thanks! Yeah ill be doing that here this week! I'm a champion guy myself. But the didn't have any instock!
