mystery vacuum Line?
Old Sep 17, 2014 | 10:09 PM
M&O Performance's Avatar
M&O Performance
Default mystery vacuum Line?
I should've named the thread missing vacuum line but oh well. cant find the line that hooked up here, any help appreciated!!
This is the line i have plugged off because i cant find where it went before.
Heres where that line goes from the t going towards the passenger side, to another t, both going into firewall
and heres where it goes towards the intake manifold, t goes into the manifold and other line goes to cruise control i believe, it runs up past the throttle cable.
Attached Thumbnails mystery vacuum Line?-20140914_134628_zps5c51af53.jpg   mystery vacuum Line?-20140914_134646_zps22b46171.jpg   mystery vacuum Line?-20140914_134652_zps120f1fa8.jpg
Old Sep 17, 2014 | 10:15 PM
The line looks collapsed... is your truck a 4x4? Does it work?
Old Sep 17, 2014 | 10:25 PM
M&O Performance
Yes 4x4. No It dosent work. But its not a line. Its a plug. Made so it wasnt sucking air. Theres a line that connects to it I just cant find for the life of me. Wanna say a 90 degree corner went off it
M&O Performance
Its marine grade shrink wrap haha
Old Sep 17, 2014 | 10:27 PM
Wonder if a line broke, and that was the 'fix'...... It does get pretty warm in there, the shrink wrap probably just did its job.
Is there a white line around there somewhere, should come up from the vacuum switch on the t-case. (there is a green one as well, but, that one is SUPPOSED to dead end, its just a vent line.)
Old Sep 17, 2014 | 10:31 PM
M&O Performance
In this pic of a diff truck I found on here doing the plenum you can kinda see the line I think but im still lost on where she goes and what she does.
Old Sep 17, 2014 | 10:44 PM
M&O Performance
And I have a full repair manual here. But it dosent show anything usefull for vacuum lines
Old Sep 17, 2014 | 10:56 PM
Should be a vacuum diagram on a sticker under the hood, probably on the radiator support. (emissions label) I don't think it shows the lines for the 4x4 though.....
Old Sep 17, 2014 | 10:58 PM
M&O Performance
Ive looked at that also. Never helped.. ill check my 4x4 tomorrow and give a update
Old Sep 20, 2014 | 01:32 PM
M&O Performance
Well 4x4 issue is just the actuator and all the lines are where they are suppose to be. So still no answers on where this line is.
