torque converter lock up switch?
Old Sep 27, 2014 | 10:47 PM
dodgetrucker75's Avatar
dodgetrucker75
Default torque converter lock up switch?
Anyone ever put one on with a gas engine?
I installed one today and it worked great, until I tried to shut the engine off, it ran u ntill I pulled the jumper wire out, witch is in place of the trans relay,
This is with my 4bt but running the gas pcm and harness, I've installed many of these on diesel trucks but never seen this before, and will not work with the relay installed, it just defaults the trans with the relay installed, the schematics seem to be the same but obviously I'm missing something, (my injection pump is controlled by the gas coil wires)
Old Sep 28, 2014 | 08:12 AM
What year is the trans?
Old Sep 28, 2014 | 11:08 AM
It's Me Patt's Avatar
It's Me Patt
And why the switch?
Old Sep 28, 2014 | 11:43 AM
dodgetrucker75
The trans is a 47re from a 97 ram
The switch is just a driveability thing with many uses, allows for quicker acceleration, being able to lock and hold it in gear, works great for breaking especially with a exhaust brake, makes lower speed/ intown driving much nicer, theres more too
Old Sep 28, 2014 | 11:45 AM
It's Me Patt
kool thanks for that
Old Sep 28, 2014 | 11:46 AM
How are you controlling the trans now?
No clue why your engine would stay running because of the trans circuit though....
Old Sep 28, 2014 | 11:55 AM
dodgetrucker75
No clue why your engine would stay running because trans circuit though....
The trans is being controlled with the pcm and everything works great, except for this switch, witch is a normal install
The next fun piece of info.... I was checking more into it and with the relay jumped and no use of the switch, everythig works fine, but if i use the switch, the engine wont shut down afterwards..... this is wierd, maby i need to find a way to operate the trans relay with the ASD circuit....
Old Sep 28, 2014 | 01:01 PM
What wire do you have the switch plumbed into? and is it providing power, or ground?
Old Sep 28, 2014 | 01:03 PM
dodgetrucker75
i made it work! for what ever reason it was back feeding, but i ran a jumper wire from the ASD relay to power the trans circuit and all is working as it should.... it must be something in my modified harness that is causing it
if any of you want to try one out for fun, here are the instructions for all 94-02 rams ---> http://www.tstproducts.com/Torque%20...p%20Switch.pdf just dont use a lighted switch, only use a normal 2 post switch
i love the lock up switches, gives you a lot of options
Old Sep 28, 2014 | 01:07 PM
dodgetrucker75
here is where i mounted mine for easy operation with my left foot
