question about harmonic bal
Old Nov 14, 2014 | 08:44 PM
GRed's Avatar
GRed
Default question about harmonic bal
Attachment 25469
Attachment 25470
Is the dodge HB a 2 piece that's connected(welded) to ea other in some way??? does it take a jaw puller or that other puller(bolt) I looked and researched and it seems one piece. and if it is, can I use either puller. It seems like it has a what I will call a hub in front of HB that seems to be attached..is this hub I can pull on with a puller and will the HB come off with that hub does anyone know?? when I looked... the HB doesn't have any threaded holes but wasn't able to see that hub in front of it.
appreciate the help
Old Nov 14, 2014 | 09:09 PM
Ham Bone's Avatar
Ham Bone
Nope you need a small block Chrysler puller. It's basically a big three jaw but it hooks on the inside.
Yeah it's a 2 piece.
Old Nov 14, 2014 | 09:14 PM
GRed's Avatar
GRed
OK, I appreciate ur response.. guess I will break down and goto autozone and get loaner... 123.00 but its refundable. I thought they held it as a dep. but found out they actually run the charge and then refund you. I didn't know that,.. my 1st time.planning to do it tomorrow, will buy it prob within next 2 wks or so just to have it..
Old Nov 14, 2014 | 09:15 PM
GRed's Avatar
GRed
is that an 8 inch do you know?
Old Nov 14, 2014 | 10:32 PM
snowboundrmk's Avatar
snowboundrmk
This is what I have. It works good.
http://t.harborfreight.com/bolt-type...set-69889.html
Old Nov 15, 2014 | 10:26 AM
Didn't chrysler change the balancer design at some point? Going from a balancer/pulley (two piece) to a single piece???
Old Nov 15, 2014 | 10:51 AM
Ham Bone's Avatar
Ham Bone
By two piece I meant it's one piece. On my 01 the pulley is bonded to the HB.
sorry for the confusion
Old Nov 15, 2014 | 12:16 PM
GRed's Avatar
GRed
So that puller will work??
Old Nov 15, 2014 | 12:17 PM
GRed's Avatar
GRed
ok.. so that makes more sense.. so a Bolt puller will work!!!
Old Nov 15, 2014 | 12:19 PM
Ham Bone's Avatar
Ham Bone
No there is nowhere to out the bolts.
