99 Dodge Ram V10-temp gauge sensor location
Old Nov 16, 2014 | 05:17 PM
Joeziahbabb's Avatar
Joeziahbabb
Default 99 Dodge Ram V10-temp gauge sensor location
I'm replacing the thermostat and was going to replace the sensors for both the computer and the temp gauge. From what info I can find, both sensors are located in the t-stat housing. However, the t-stat housing on this engine has only 1 location and it's for the computer temp sensor. I cannot find another location for the temp gauge sensor. Would the computer relay the temp info to the gauge as well? Any ideas?
Old Nov 16, 2014 | 05:35 PM
Being a 99, I think you only have the one sensor.
Old Nov 17, 2014 | 11:57 PM
Joeziahbabb
Ok. Thanks for the help. There must be only 1 sensor. But, I'm back to where I started - no heat.
Old Nov 18, 2014 | 03:55 AM
pinkrosi's Avatar
pinkrosi
Im thinking my antifreeze/water ratio was off.
A few months ago I replaced a radiator hose and flushed the system. Only drained it at the radiator drain and added 50/50 antifreeze.
I knew better. I should have checked.
___________
We are the pioneers in providing 640-554 braindumps dumps and cca.edu tutorials with 100% exam pass guarantee. Download our latest hodges & Braindumps.com questions.
Old Nov 18, 2014 | 10:09 AM
Does the temp gauge come up? Engine make it to operating temp?
Old Nov 13, 2022 | 09:15 AM
Hollywood1978's Avatar
Hollywood1978
having same issue replaced sensor, replaced sensor plug,replaced water pump the needle on temp gauge won't move off cold
Old Nov 13, 2022 | 05:05 PM
69_XS29L's Avatar
69_XS29L
What is your ambient?
Hey You is right. Does the thermostat housing even get hot? V-10 is designed with a constant bypass of coolant to warm the engine slowly, help maintain cylinder seal.
Unless you are down around zero, don't think you could overcool a V-10.
Early V-10 had two temp sensors. After '97, only one.
Old Nov 16, 2022 | 02:34 PM
adukart's Avatar
adukart
Ok is your motor warming up and heater working?
