Should use power steering fluid in the power steering system....
I did but Chrysler technicians put it in any systems they work on, I asked them bout it. I've tried with normal steering fluid. And alright, I will try and do that tomorrow. The new gear box makes a snap/cracking noise at certain points thru the steering cycle. If I cut really hard there's other terrible noises. Getting so bad that I have to accelerate thru turns or else I will lock up. Still waiting to meet for a flow test. Thought about removing the belt and seeing what it's like to turn the pulley by hand? Is that even worth it?
AND THE RESULTS HAVE COME IN! I flow at 2.0 gpm at idle, about 40psi. When I attempt to steer, the gpm drops to absolute 0, and psi goes through the roof! Off the gauge it was so high. When you rev (and don't steer) I could only get the gpm to about 2.5 and no higher.
