Ignition Sw Halo light
Old Dec 26, 2014 | 02:39 PM
scotty088's Avatar
scotty088
Default Ignition Sw Halo light
Can you tell me how this ignition switch halo light is supposed to work? Is it on with the key or the headlights on or with the ignition on. Mine has never worked, I have replaced the ign.switch, I still can't seem to make it work. If I knew how it was supposed to function maybe it would be easier to find a solution.
As always thanks for all your guidance,
Scotty
Old Dec 26, 2014 | 10:24 PM
What brand lights do you have?
Old Dec 27, 2014 | 02:09 PM
scotty088's Avatar
scotty088
Sorry,I didn't explain myself properly. The circular light that surrounds the ignition lock cylinder where you insert the key.That is the light I'm trying to figure out how it is supposed to work.
Old Dec 27, 2014 | 02:10 PM
scotty088's Avatar
scotty088
Guess I should learn to compose in English.......
Old Dec 27, 2014 | 02:50 PM
beeker's Avatar
beeker
I understood you just fine. Mine has never worked either. I'd like to know if it's supposed to work or if it's something Dodge designed and then never finished to save money.
Old Dec 27, 2014 | 03:37 PM
Should be on a timer. Depends on what year your truck is as to what actually controls it.
Old Dec 27, 2014 | 07:09 PM
scotty088's Avatar
scotty088
Mine is a 94 Ram 1500 4x4. 5.2 v/8. If I knew how it is supposed to work maybe I could fix it.
Old Dec 28, 2014 | 11:11 AM
There is a timer relay in the fuse block on the drivers side of the dash that should control it. Wonder if the bulb is just burnt out....... I suspect changing it would be interesting.
You can download the 95 service manual from this thread. Should show ya something in there.
Old Dec 28, 2014 | 01:52 PM
scotty088's Avatar
scotty088
this light setup comes with the new ignition switch that I have replaced. It has a new bulb included that was checked before install. What would be the location of the timer relay in the P.D.M. ?
Old Dec 28, 2014 | 01:53 PM
scotty088's Avatar
scotty088
I can't find anything in the service manual......
