flexplate & torque converter
Old Feb 4, 2015 | 08:04 PM
beau680's Avatar
beau680
Default flexplate & torque converter
Does the flex plate have to be installed in a certain position? As in a certain way for the cam or crank sensor to pick up where it is or will the ecu do that for me?
An how many times does the torque converter have to drop to be in the correct position I think I counted twice?
Old Feb 4, 2015 | 08:27 PM
Flex plate should only bolt on one way. Depending on which motor you have, torque converter may be the same. Only goes one way.
Old Feb 4, 2015 | 08:38 PM
mynah1's Avatar
mynah1
The flex plate bolt pattern goes on one way, in other words the holes will only line up in one way. Pick up break points won't change.
Sorry I don't understand your last question. The TC is pushed away from the drive plate when removing the engine or transmission. Upon re-installation, pull the TC toward the drive plate, make sure it spins freely centering the TC hub in the crank shaft, find where all the holes line up and torque to 24' lbs. (if I remember correctly)
Old Feb 4, 2015 | 09:55 PM
beau680's Avatar
beau680
Well I guess what I'm asking is how to set the torque converter you know turn it either counter clock wise or clock wise and how many seats does it take to be fully set into the appropriate spot
And how about any idea on why my flywheel is welded onto my torque converter ?
Old Feb 4, 2015 | 10:35 PM
Dodge put the starter ring gear on the torque converter for some strange reason. I do not pretend to understand why.......
Turn the t/c any direction, doesn't matter, don't torque the bolts down right away though, put them in slightly less than finger tight, and make sure all of them line up, and thread in, then just go around one more time, and torque them to spec.
Old Feb 4, 2015 | 11:33 PM
snowboundrmk's Avatar
snowboundrmk
You've got it right torque converter drops in twice. I believe first is the splines on the input shaft and second is the pump. There should be a small gap between the flex plate and converter, but as you tighten up the bolts it will pull forward against the flex plate.
Old Feb 5, 2015 | 12:25 AM
beau680's Avatar
beau680
Cool that's what I thought just had to be sure I recall a Tahoe I used to have took three seats
Old Feb 8, 2015 | 07:47 AM
newman1367's Avatar
newman1367
To make a $20 part way more expensive.
