drilling front pinion bolt hole?
Old Feb 25, 2015 | 07:16 PM
cutthroatxxx's Avatar
cutthroatxxx
Default drilling front pinion bolt hole?
Ok so I've slowly been piecing this thing back together & now with new t case in.I go to hook up the front driveshaft but when I grab the t straps I notice 1 of the bolt holes on my front pinion yoke @ differential it too big.Ofcurse the part is expensive & I just spent 7 grand in the past 2 weeks so I'm about busted.Can I just drill the hole out, use a longer bolt & add a nut to the backside? Let me know please.
Old Feb 25, 2015 | 07:18 PM
Ham Bone's Avatar
Ham Bone
Oriellys sells replacement straps and bolts for like 5 bucks.
Old Feb 25, 2015 | 07:20 PM
cutthroatxxx
It's not the strap it's the part the strap bolts to, that the hole is too big the front pinion
Old Feb 25, 2015 | 07:30 PM
Ham Bone's Avatar
Ham Bone
I don't follow.
Old Feb 25, 2015 | 07:34 PM
Moparite's Avatar
Moparite
Helicoil it! There is another brand out there to i think it's called re-coil. Some kit's come with the drill bit. Just make sure you have the drill bit before you buy it.
Old Feb 25, 2015 | 07:37 PM
cutthroatxxx
Originally Posted by Ham Bone
I don't follow.
it's the front differential pinion yolk
Where the pinion yoke coming out of the differential where the bole goes through the u strap then into the yoke, the bolt hole is too big.I want to know can I just drill it out use a long bolt & add a nut..I hate help coils btw
Old Feb 25, 2015 | 07:42 PM
Moparite's Avatar
Moparite
Why? They work just fine if you do it right. If drill it out and can put a nut on the back it may unbalance it enough to feel it while driving.
Old Feb 25, 2015 | 07:43 PM
Ham Bone's Avatar
Ham Bone
Is it all messed up or do you just have the wrong bolts.
Old Feb 25, 2015 | 07:47 PM
cutthroatxxx
It's just 1 of the 4 holes.The bolts fit in the other 3 holes
Old Feb 25, 2015 | 08:22 PM
So one of your holes is stripped out. Could just replace the yoke...... Though at advance its 120 bucks..... but, that would be fixing it "right"™, which I highly recommend.
