Warmer weather causing long crank?
Old Apr 8, 2015 | 08:09 AM
BrandonBuc'em's Avatar
BrandonBuc'em
Default Warmer weather causing long crank?
Spring is here. This last week it's been nice out, 60-75 degrees. I start to the truck at 6:15 every morning. Fires right up. I Park it and don't start it again til 9:30, it will long crank. Park it from 9:45-11:20 and when i turn the key it she long cranks. I should note that if I shut the truck down and turn it back on it fires up just fine. It seems to be when I let her sit in the heat of day for a period of time, she long cranks.
am I looking at a bad sensor here? A buddy said the crank sensor is to blame but I can't locate the darn thing behind the block. Any help is appreciated as always.
And I know...another long crank thread! lol
Old Apr 8, 2015 | 09:44 AM
Ham Bone's Avatar
Ham Bone
what are considering a long crank?
Old Apr 8, 2015 | 09:54 AM
BrandonBuc'em
Like turn the key and it cranks for 3-6 seconds and finally will sputter to life. Once it's running, no issues. Reaches operating temperature and functions 100 percent.
Old Apr 14, 2015 | 10:07 PM
BrandonBuc'em
bump...
Old Apr 15, 2015 | 05:19 AM
UnregisteredUser's Avatar
UnregisteredUser
Fuel pressure bleed, perhaps? What happens if you turn the key to On for a few seconds at a time when you expect slow starting, then back to Off, and then try a few second after that to start it as usual?
The crank sensor is a shy creature one can find only by really wanting to find it, and approaching it carefully.
Old Apr 15, 2015 | 10:38 AM
Ham Bone's Avatar
Ham Bone
Do what unregistered user says. Cycle the key to on, wait a couple seconds. Then cycle it back off and repeat this a few times. Then start it up like normal. If it starts fine then the fuel pump regulator is not keeping the line pressurized.
Old Apr 15, 2015 | 11:30 AM
chromed95's Avatar
chromed95
Must be that ghost trailer you're pulling causing ghostly things to happen
Though it does sound like fuel pressure, I'm a little skeptical he's bleeding fuel pressure that fast during the day, when sitting overnight he says it fires right up in the morning. If that were the problem I would think he'd be having starting issues in the morning too. Try folding your mirrors down
Maybe MAF sensor on the fritz?
Old Apr 15, 2015 | 11:41 AM
Ham Bone's Avatar
Ham Bone
Maybe he parks downhill at home? Haha I forgot about that part.
Still, worth a try.
We have map sensors not maf
Old Apr 15, 2015 | 12:43 PM
chromed95's Avatar
chromed95
oops, I did mean map, good catch. I was fighting a maf on another car this last weekend
Old Apr 15, 2015 | 05:56 PM
BrandonBuc'em
below is a video of the condition i explained. at night i park on level ground. it fires right up with no hesitation and no issues. its only when it is warmer outside and sits for a period of time.
