98.5 header to y pipe gasket??
Just replaced my header gaskets on my hedmen shorties with proform aluminum gaskets and stage8locking bolts. Headers are sealed 100% now, but the flange is leaking. I'd like to replace the donut gaskets but am having a very hard time finding them, if they're supposed to be there at all
i have a question about locking bolts. our manifolds use 2 studs and 2 bolts correct? so do you replace the 2 bolts with studs or just use the locking kit on the studs? im considering headers when i replace my y pipe and cats
headers usually have a uniform thickness mounting flange front to back, so, bolts will actually work...... sometimes there are fewer clearance issues for the bolt heads as well. (Alan head bolts tend to take care of any clearance issues, but, not sure you can get locks for them.
I heard 2nd gen mafia on Facebook it's not supposed to be there. Scraping my old headers the instructions sheet showed just the ball and socket coming together, no gasket. Now i have to figure out how to seal these :/ guess I'll try a crap ton of orange rtv around them
RTV will just burn off. Gets pretty hot there...... wonder if things just aren't aligned quite right. Wouldn't be the first time. Could try loosening up the y-pipe on both sides, and see if you can't get a slightly better fit?
