Ticking sound i cannot locate
Old Jun 5, 2015 | 01:40 AM
BrandonZane's Avatar
BrandonZane
Exclamation Ticking sound i cannot locate
I recently purchased a 95 5.9L 1500, I have noticed a clicking noise that sounds like it is coming from the passenger side. Weird part is that I can only hear it when driving past parked cars, guardrails, or pretty much any solid object that would cause a reflection of the sound. I have not heard it at idle, Its making me slightly nervous. I just recently replaced front and rear brake assembly's so i dont believe that is the issue. Any suggestions as to what this could be would be greatly appreciated!
Old Jun 5, 2015 | 07:40 AM
jrox44's Avatar
jrox44
Mine does the same things. It's the tensioner pully. The spring tightening and loosing . It's old. Not bad but when they get old the spring clicks. Watch the pully while the motor is running you will see. Or the AC compressor clicking on and off
Old Jun 5, 2015 | 08:53 AM
Moparite's Avatar
Moparite
4X4 or 4X2? If it's a 4X4 it's most likely worn ujoints(wheel).
Old Jun 5, 2015 | 11:21 AM
BrandonZane
Thumbs up
Well i'll check those both out, appreciated guys! Oh and its 4x4.
Old Jun 5, 2015 | 11:23 AM
BrandonZane
Are either of these problems that i should worry about breaking while im driving down the road? I drive long distances on the freeway for work... Kinda new to working on vehicles sorry for the noob questions lol
Old Jun 5, 2015 | 11:26 AM
Ramman18's Avatar
Ramman18
If it is speed sensitive: meaning it slows and speeds up depending on your vehicle speed, then yes, I agree it to be the u-joint.
If not, then you have some investigating to do. I have never heard my tensioner make any noise at all.
Old Jun 5, 2015 | 11:29 AM
BrandonZane
If it is the u-joint that is the issue, shouldnt i be able to (for lack of a better term) wiggle it?
Old Jun 5, 2015 | 01:20 PM
BrandonZane
Question
Well, I started my truck this morning and upon inspecting under the hood, i could not hear the clicking noise i was previously describing, Which leads to me to believe that you both are correct about it being the u-joint. Is there a way that i could test this theory without having to pull apart my wheel assembly first?
Old Jun 5, 2015 | 03:02 PM
See if they have any slop to them.
Jack up the front, turn the wheels, and then roll the tires back and forth a bit. Hear any noise?
Old Jun 5, 2015 | 03:36 PM
BrandonZane
I did not hear any noise besides my brake pads slightly grinding. ( a metal on metal noise)
