Torque Converter Instal
Old Jun 18, 2015 | 05:20 PM
Eagleye134's Avatar
Eagleye134
Default Torque Converter Instal
Gotta quick question on torque converters guys, so I pulled my motor and the torque converter came off with the motor (even after I removed the 4 bolts form the flex plate) My question is how do I index it back onto the transmission and did I damage any pumps in the transmission by removing the torque converter with the motor?
Old Jun 18, 2015 | 05:54 PM
Since it is already out, replace the seal on the trans. Chances are good you damaged it on removal in any event.
There are two notches on the t/c, that engage dogs on the trans pump. Line 'em up, stuff it in, and you are done. T/C should be recessed back into the bellhousing at least an inch or two when fully seated. (you may have to draw it out a bit to thread the bolts in, once the engine is back in place.)
Old Jun 18, 2015 | 07:36 PM
Eagleye134's Avatar
Eagleye134
Does that seal just pry out? Or do I need a puller? And what would that seal be called a parts store, trans front seal?
Old Jun 19, 2015 | 08:59 PM
Or torque converter seal. And yep, it's just like any other seal. Can pry it out with a screwdriver, drive it back in with the right-sized piece of pipe. Trying to just tap around the outer edge with a hammer is a major pain... and rarely works. Seal driver would be REALLY nice, if you can get your hands on one.
Old Jul 5, 2015 | 07:59 PM
Eagleye134's Avatar
Eagleye134
okay I got the seal! I lined the dogs up on the pump best as I could, is there any other way to tell if the dogs are in the t/c ? I have my torque convertor in and its recessed into the housing an inch, but I just wanna be sure because the t/c wiggles up and down "slightly" with my hands.
Old Jul 6, 2015 | 10:10 AM
Sounds like you have it in place. Bolt the trans up, and the t/c should still be a little bit back from the flexplate. (and should spin freely.)
Old Jul 6, 2015 | 01:36 PM
Eagleye134's Avatar
Eagleye134
Is there any reason to fill the t/c before install?
Old Jul 6, 2015 | 03:37 PM
Not really, just start the truck in neutral, so it will fill right away.
Old Jul 6, 2015 | 11:36 PM
horatio102's Avatar
horatio102
Gassers will have the torque converter recessed 3/4" or so.
Diesels (and maybe V10, never worked on one) the torque converter actually sticks out a bit.
That's one point of clarification not made in the ATSG manual.
