4wd indicator light always on
Old 06-30-2015, 05:31 PM
Fortin_joey's Avatar
Fortin_joey
Fortin_joey is offline
Default 4wd indicator light always on
2001 ram 2500 sport diesel 4wd indication light always on, I have checked the indicator switch on cad and working, I have also tried unplgin the cad 2 switch wires and light still on, I have also unplugged it just in front of the ac pump before going into the main harness and light still on, my 4wd does engage and disengage as it should, both wires going to the cad are grounded... Where is a common place for these wires to short? What am I missin?
Old 06-30-2015, 06:15 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,198 Likes on 2,950 Posts
Grab the 01 service manual from this thread. have a look at the wiring diagrams...... Seems strange that you light stays on all the time.... gotta be a short somewhere though....
Looks like the wiring coming from the indicator in the cluster is powered, and the switch just grounds the circuit. Unfortunately, that means anywhere along that wire, it could be grounding out.
Old 06-30-2015, 06:29 PM
Fortin_joey
I've looked and looked for a service manual or even just a wiring diagram for that and couldn't find anything, from what I understand the indicator switch is a ground wire, just knowing what wire is grounded to chassis would help lots! And Id be guessing the other wire would go up to the cluster? Knowing what wire is shorting and where it goes I could try passing a new wire
Old 06-30-2015, 09:30 PM
HeyYou is offline
Ooops. I neglected to put in the link. Sorry 'bout that.
Find your service manual in PDF format Here.
Quick Reply: 4wd indicator light always on
