1995 Dodge Ram 1500 5.9L 4x4
Old Jul 6, 2015 | 05:53 PM
JoshuaYsassi's Avatar
JoshuaYsassi
Default 1995 Dodge Ram 1500 5.9L 4x4 Stalling Please Help
Can somebody please help me I am stuck on what is wrong with my truck. The truck will start up fine and will also idle but when put in drive it will go for a couple of feet then die.. The oil pressure will go down a little when gas pedal is pushed ..There is no rough idling or noises from engine and no check lights on
Old Jul 6, 2015 | 06:35 PM
Anything binding? Is it struggling to move? If you let it sit and idle, will it continue to run? How many miles on the truck?
Old Jul 6, 2015 | 06:43 PM
JoshuaYsassi
Nothing is Binding, No struggle to move , will sit in idle and run fine and it has 200,xxx but just overhauled whole transmission and put a high stall Torqure converter in it... It sits in idle fine but when put in drive and starts going it stalls
Old Jul 6, 2015 | 08:33 PM
Does it jerk like dropping the clutch on a manual trans?
Old Jul 6, 2015 | 08:39 PM
JoshuaYsassi
No jerking shifts fine just dies when put drive and starts going
Old Jul 6, 2015 | 08:43 PM
Just noticed "overhauled trans"...... Frequently, the crank position sensor is a victim of such happenings. It gets bent/crushed/spindled/mutilated during the swap, and stops working right. Think I would be tempted to pull it, and see what it looks like. If it's damaged, get one from the dealer. Yes, its more expensive, but, our trucks don't much care for some of the aftermarket sensors in critical places.
Old Jul 6, 2015 | 08:54 PM
JoshuaYsassi
I put a brand new one in when we changed transmission I'm thinking it is the torque converter clutch soleinoid or the air idle Valve
Old Jul 6, 2015 | 10:29 PM
When you start it cold, where does it idle at? As it warms up, does the idle come down?
What brand sensor did you get?
Old Jul 6, 2015 | 10:42 PM
JoshuaYsassi
Not sure where it starts but I know it will stay around 800 rpm but oil gauge will move and when pushing down on the gas the oil drops and not sure on brand I got it from orielys
Old Jul 6, 2015 | 11:05 PM
JoshuaYsassi
I check the engine codes a code 37 and 51 came up
37- Torque Converter Clutch Soleinoid
51- Fuel Lean
