Transfer case 4x4 vacuum lines
Old Nov 28, 2024 | 10:29 PM
  #21
Lilred99's Avatar
Lilred99
Not a cap, just a filter. Supposed to keep dirt out.... Not sure how effective it is at keeping water out. In my experience, if falls into the 'not very well', or possibly 'useless' category.
Oh, well either way it's not there lol so I figured I'd get a new one since I'm messing with everything down there.
Old Mar 16, 2025 | 11:31 AM
  #22
Lucky-99's Avatar
Lucky-99
Default Transfer case swap
Metal line probably used to have just a cap on it, so it was vented, but, was less likely to suck water. It didn't hook to anything. Line was just hung out of the way somewhere. (likely had a bracket that bolted to one of the bellhousing bolts.)
On the rest, yep, should work just fine.
I replaced my transfer case and while I was disconnecting the vacuum lines I noticed a line that was in my way. I removed it and set it aside. Once I got the new transfer case (3 weeks later) I went to installing it. I got the vacuum lines that run to the CAD on the 4 prong switch installed and the other hose that was tied to the 4 lines on the vent on the transfer case. After I completely installed everything I noticed the line I took out and completely forgot where it went to or how it attached. It says on the line Transfer Case Vent 5/16 185192634. It has a red clamp on one side and a metal hard pipe on the other with a hangar next to the metal pipe. Any help would be appreciated
Old Mar 16, 2025 | 11:42 AM
  #23
Where did that line go to/come from?? What color is it?
Old Mar 16, 2025 | 11:46 AM
  #24
Lucky-99's Avatar
Lucky-99
Line is black with white lettering that says it’s the transfer case vent. Would it connect to the 5 lines that was attached to the 4 vaccum hoses that connect to the switch?
Old Mar 16, 2025 | 11:48 AM
  #25
Lucky-99's Avatar
Lucky-99
Also it looks like there is a space for the line to sit next to the fuel lines that run along side the drivers side of the truck along the frame
Old Mar 16, 2025 | 12:10 PM
  #26
Vent line went from transfer case switch, up behind the motor. It's just a vent, so, it doesn't connect to anything on the upper end, just secured in place wherever you can find a good spot.
Old Mar 16, 2025 | 07:22 PM
  #27
Lucky-99's Avatar
Lucky-99
Just got everything installed and checked all the vacuum lines made sure they were on good. Now my truck won’t shift into drive or reverse. Also when I shift into park it makes a groaning noise. I made sure the transmission fluid was topped off. I’m at a loss here
Old Mar 16, 2025 | 08:00 PM
  #28
Is the t-case in neutral?
Old Mar 16, 2025 | 08:23 PM
  #29
Lucky-99's Avatar
Lucky-99
No and I shifted the transfer case into all of the gears and tried to put it in drive and reverse and still nothing
Old Mar 16, 2025 | 08:47 PM
  #30
Why did you replace the t-case in the first place? Was it because the truck wouldn't move??
