Transfer case 4x4 vacuum lines
Old Jul 7, 2015 | 01:06 AM
Eagleye134's Avatar
Eagleye134
Default Transfer case 4x4 vacuum lines
Soo I got my engine out of my truck, a 1996 5.9L with a 46RE trans; and noticed that the lines coming from the transfer case dont look right. My question is what are they for (from the 4-line connector at the case) and where do they hook up? I have the red and black ones perfect and redone, but the green and white vacuum lines are open at the ends, where do those hook up? Also I have another vacuum line (or so I think it is a vacuum line, but its just a big black rubber line) with a bracket held on by one of the trans to block bolts, what is that for because it has a metal line coming out of it but that metal line has rusted and broke and just sitting there open.
Old Jul 7, 2015 | 09:45 AM
White vacuum line goes to the bag 'o snakes on the passenger side rear of the engine. That's source vacuum for the 4x4. The green line is just a vent, position it up somewhere out of the way. Do not cap it.
Large hose is vent line for the t-case, or front axle. Same thing there. Up high, not capped.
Old Jul 7, 2015 | 01:02 PM
Eagleye134's Avatar
Eagleye134
White line to the reservoir lines with the check valves correct? I got a factory vent plug that fell off from the green line ima put back on. The black rubber line I could just leave alone correct? Where did that metal line use to hook up?
Old Jul 7, 2015 | 02:11 PM
Metal line probably used to have just a cap on it, so it was vented, but, was less likely to suck water. It didn't hook to anything. Line was just hung out of the way somewhere. (likely had a bracket that bolted to one of the bellhousing bolts.)
On the rest, yep, should work just fine.
Old Jan 2, 2021 | 09:12 AM
JDoubs's Avatar
JDoubs
Question Questions of vent lines
What do you mean by bag of snakes it all started when my original V10 puked out put in another and never marked anything I have no 4x4 I found vent hoses off of transfer case green and white but have no idea where they hook up
Old Jan 3, 2021 | 10:18 AM
The white line goes to all the vacuum lines on the passenger side of the engine. Green line is just a vent, and was tucked up out of the way behind the engine. (yeah, that should be fun with the 8.0, just not a lotta room back there......) Do your HVAC vents work properly?
Old Jan 3, 2021 | 10:39 AM
JDoubs's Avatar
JDoubs
ya not alot of room at all behind motor I found a bunch of vent hoses some hooked up some not. Does it matter if I just hook them up I can try to send a pic of what I'm looking at today. The hvac system never really tried the truck is usually just used as my plow truck but I did see a aluminum line has a kink in it I'll give a try later on. I am working on my charger today pulling 383 out to put 440 in. But I will get a pic for you though thanks for the help I'm lost when it comes to this
Old Jan 3, 2021 | 10:47 AM
We want pics of the charger too.
If you don't have one yet, get a service manual for your truck from here. Pretty sure there are diagrams of the vacuum lines in there. (finding them might be fun....) This is something I get to play with soon as well, as my 4x4 has become reluctant to engage.... but, it's COLD out, and snowing... don't have heat in my garage, and I am in self-quarantine for a few more days yet, as I was exposed to sick people...... (I have no symptoms as of yet, and it's been more than a week......)
Old Jan 12, 2021 | 10:58 PM
Xombi's Avatar
Xombi
Sonnex in their instructions for the screw in adaptor states you have to revert to the old rooster comb. Master tech said the valve bodies as well. Is there a difference between valve bodies? Could as 2001 go on a 2002 case?
Contact a chrysler dealer with serial numbers of transmissions? To see if the valve body is the same?
Old Nov 26, 2021 | 11:53 PM
justin935's Avatar
justin935
Extremely helpful guys my father passed when I was 11 I'm 26 now and I'm on my second trial run doing a motor swap on his 99 2500 and thanks to you guys I know why I have no 4x4 consider I melted the white line when I did the first motor swap 5 years ago screw that junkyard motor bs she's all brand new now 4 grand later
