Transfer case 4x4 vacuum lines
Old Mar 16, 2025 | 09:04 PM
  #31
Lucky-99's Avatar
Lucky-99
I replaced it because as I was going down the road I heard a horrible grinding noise and the manual shifter for the transfer case was moving and shaking freely. Very rapidly as well. I opened the port on the back of the tc (the one to add fluid to if you need to since I figured that was the issue) and noticed the gear that’s visible was all chewed up from the grinding.
Old Mar 17, 2025 | 08:32 AM
  #32
So it drove fine, aside from being noisy..... before you swapped it? Where did you get the replacement from?
Old Mar 17, 2025 | 01:29 PM
  #33
Lucky-99's Avatar
Lucky-99
It didn’t drive fine it kept switching in and out of four wheel drive and then the shifter went crazy. I got the new transfer case from a relative. Same gear ratio, NP241 DLD. The only difference with the newer one is off of a 3rd gen and I have a 2nd gen
Old Mar 17, 2025 | 03:56 PM
  #34
Wonder if the spline count on the input hub on the t-case is different on third gens......
