Love my 01 Ram but i want more power. Engine swap?
Old Jul 26, 2015 | 11:26 PM
  #31
Mt01's Avatar
Mt01
What would you suggest for 400-450 HP 408 conversion or anything else?
Old Jul 26, 2015 | 11:27 PM
  #32
Ham Bone's Avatar
Ham Bone
Originally Posted by Adobedude
Mild 408...FTW.
I had a pile of parts for my 98 2500, R/T heads, M1 2bbl, Harland Sharp 1.7s, Pacesetter LTs, etc etc....I had my transmission rebuilt with a better converter...It pulls so much better now I sold all the parts except the headers, I still plan on those on one of these days. It tows my Dakota to the strip just fine, a 408 would be over kill for me.
You shouldve sold your RT heads and rockers to me....
Or donated them lol.
You can find third gens all day for 10 grand. 2500 5spds. Whatever you want. A 1500. Even the early 5.7s push 350 something.
Old Jul 26, 2015 | 11:32 PM
  #33
Mt01's Avatar
Mt01
Thanks i think doing the 408 may end up being cheaper than 10k Im not sure really untill i get an exact quote from some places.
Old Jul 27, 2015 | 06:56 AM
  #34
beeker's Avatar
beeker
They also make a procharger for the Magnums. For $5k you could bolt on an additional 100hp.
Old Jul 27, 2015 | 07:50 AM
  #35
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
Here's a 408 Stroker Short Block that will work. Still need heads, intake, etc...
http://www.summitracing.com/parts/hp...iew/make/dodge
Old Jul 27, 2015 | 03:33 PM
  #36
Mt01's Avatar
Mt01
What all would i need for that block to be complete? This route looks promising
Old Jul 27, 2015 | 03:41 PM
  #37
Khris1994's Avatar
Khris1994
Default Love my 01 Ram but i want more power. Engine swap?
Cam, lifters, push rod, timing chain, heads, intake, throttle or carb, valve covers, distributor, wires, plugs, etc... The whole top end
Most parts can be swapped from the old motor
Old Jul 27, 2015 | 03:45 PM
  #38
1997JollyGreenGiant
That would take care of your block and rotating assembly. You would still need cam, timing set, heads, rockers, lifters and pushrods, timing cover, front main seal, oil pump, oil pan, intake manifold, and probably a few more odd and end parts. That short block takes are of your engine block, crankshaft, rods, pistons, rings, bearings, and the block has already been bored out properly so no need to go to a machine shop, which is a benefit. The rest of the parts that you buy depend on your budget and uses for the truck. For a 408, I'd probably go with EQ 2.02 heads, a low duration cam shaft, 1.6 roller rockers, 50-52mm throttle body, M1 intake, and a good custom tune.
Old Jul 27, 2015 | 04:11 PM
  #39
Probably not a bad deal there, considering its all forged parts.... Doesn't talk about what kind of dish on the pistons though....... Wonder if you could order one direct from the manufacturer, and specify pistons.......
Edit: Checked it out..... yeah, that is going to be close to 10:1 compression with 64cc heads.... Holy smoke.
Old Jul 27, 2015 | 04:12 PM
  #40
stewie01's Avatar
stewie01
Could get creative and swap in a diesel
