no start in park, only neutral
Old Aug 15, 2015 | 11:26 AM
lisa99's Avatar
lisa99
thank u
Old Aug 15, 2015 | 04:52 PM
lisa99's Avatar
lisa99
can it get any better for me? As I was loosing bolts to the valve body the retainer to the front band fell out. woohoo. How do I get the valve body off to fix it.
Old Aug 15, 2015 | 04:58 PM
lisa99's Avatar
lisa99
I loosened the bolts for the valve body and the retainer fell out. Can I move the valve body out of way or do I have to remove it completely?
Old Aug 15, 2015 | 07:34 PM
If you can, just shuffle it over to the side enough to deal with what you need to. If you still can't get it, you'll have to pull it.
Old Aug 16, 2015 | 11:18 AM
lisa99's Avatar
lisa99
cant move it over. loosened nuts for throttle linkage, removed spring,loosened larger nut, still cant remove the linkage, afraid its going to break
Old Aug 16, 2015 | 11:58 AM
can you post a pic? Is this the external linkage? Or internal? Service manual have any insight? ( I don't really do auto transmissions....... just stuff I have learned over the years.)
Old Aug 16, 2015 | 12:28 PM
lisa99's Avatar
lisa99
I DID IT! Got the valve body down. replaced the retainer for band, snug again. and I found my problem, broken spring in the accumulator. Lost a week from my life, ruined many clothes and yes dawn takes tranny fluid out of hair. Now to put everything back should be alot easier right? Chalk one up for the female back yard mechanic. Thanks guys again for all your help
Old Aug 19, 2015 | 02:58 PM
lisa99's Avatar
lisa99
my excitement was short lived. truck does start in park, but now wont move. WTF
Old Aug 19, 2015 | 03:41 PM
LoneWolfArcher's Avatar
LoneWolfArcher
See if the linkage came undone. Sometimes adjusting them causes the pin that hold is on the trans linkage to break, and then it slips off. 10 cent cotter pin will fix it.
Is the shifter really loose like it isn't connected?
Old Aug 19, 2015 | 03:51 PM
lisa99's Avatar
lisa99
i checked its tight
