New throttle position sensor causing truck to smoke
Old Aug 13, 2015 | 05:21 PM
Samenko's Avatar
Samenko
Default New throttle position sensor causing truck to smoke
I just put a new throttle position sensor on my 01 dodge 5.2l after installing truck started off by surging then once i re- adjusted the new sensor quit until i took it for a drive to town and it began a poping in park then began dumping out blue smoke. is the sensor bad (duralast with lifetime waranty) or does the truck just not like it?
Old Aug 13, 2015 | 05:25 PM
Blue smoke is oil, not fuel.
Did you reset the PCM, so it could learn the new sensor? If not, just disconnect the battery for about 10 minutes, hook it back up, turn the ignition to on, (not start) count to 10, THEN start the truck. (don't touch the gas pedal)
Does the smoke clear up after a bit?
Old Aug 13, 2015 | 05:36 PM
Samenko's Avatar
Samenko
thats what is confusing me is that its a blue smoke and it has seldomly smoked but when it has never this much. i unhooked the battery but may have got a little impatient on hooking it up ill try it agai
Old Aug 13, 2015 | 05:45 PM
Unhook the battery, turn the lights on for a minute, turn the lights off, hook up the battery. That will make SURE everything is discharged.
Old Aug 13, 2015 | 06:01 PM
Samenko's Avatar
Samenko
Just got threw doing all of that and still was getting the same problems. This one has me scratching my head the tps fixed the floating rpms but gave me more new problems
Old Aug 13, 2015 | 06:07 PM
Possibly bad sensor, or, the PCM simply just doesn't like it. Wouldn't be the first time a dodge truck refused to play nice with a duralast sensor.....
Another possibility is: Something else failed, and it just had strange timing...... How much blue smoke ya gettin'? Do you have a consistent miss, even at idle? Engine making any odd noises?
Old Aug 13, 2015 | 06:53 PM
Samenko's Avatar
Samenko
i took the new off and re installed the old hoping it will smooth back out and take the new back. There a good bit of smoke once the gas is hit ill get a large cloud big enough for me to see it float away.
Old Aug 13, 2015 | 06:54 PM
Samenko's Avatar
Samenko
and on the engine only sound out of place is a pop through the exhuast its faint and only when in park and idling
Old Aug 13, 2015 | 08:07 PM
Wonder if you have a hung valve. Can you tell which side it is coming from?
Old Aug 14, 2015 | 12:00 PM
Ramingo's Avatar
Ramingo
Check your PVC valve, it might of gotten stuck or failed. That has happened to me more than a couple times..
