Doesn't like the rain
Old Sep 28, 2015 | 09:53 AM
jh360's Avatar
jh360
Arrow Doesn't like the rain
I have a 95 ram 1500, that doesn't like rain. it runs fine for a mile or so then drops cylinders and wont pull. it will idle however. after a few days of no rain it runs fine. Need some ideas, computer, cap rotor ,wires, coil, have all been changed. it does however have 325,000 miles on it. never touched.
Old Sep 28, 2015 | 09:57 AM
LoneWolfArcher's Avatar
LoneWolfArcher
Had an 89 Camaro and in the early 90s had this same problem. Distributor rebuild fixed it.
Old Sep 28, 2015 | 10:12 AM
jh360's Avatar
jh360
I have replaced everything in and around the dist.
Old Sep 28, 2015 | 10:30 AM
Broke this out into its own thread.
What all have you replaced?
Old Sep 28, 2015 | 10:39 AM
jh360's Avatar
jh360
computer, cap, rotor, wires, plugs, dist module, coil. And has never turned engine light on when this happens
Old Sep 28, 2015 | 10:40 AM
Is the seal for the hood, right above the dist cap in place?
Old Sep 28, 2015 | 10:46 AM
jh360's Avatar
jh360
yes it is, but did have to re-glue it once. The funny thing about this is it only does it if it sets in rain, and then try to go. wont do it if your driving when it starts to rain.
Old Sep 28, 2015 | 11:22 AM
I would be tempted to open the hood, start it up, and start spraying water around, see what happens. I suspect it is ignition related.
What plug wires did you get?
Old Sep 28, 2015 | 12:45 PM
jh360's Avatar
jh360
bought everything from Dodge dealer. I will try the water thing.
Old Sep 28, 2015 | 07:28 PM
jh360's Avatar
jh360
been out working on it. Its been raing here for 4 days.. so truck still doing it. Replaced cap and rotor again. Plus MAP sensor....to no avail..
