Misfire monitor
Old Sep 29, 2015 | 01:21 AM
360_magnum's Avatar
360_magnum
Default Misfire monitor
When the misfire monitor goes complete does that mean there is no misfire? I'm trying to help out a friend with an issue I think we have fixed just wanting to be sure.
Old Sep 29, 2015 | 09:39 AM
What was the issue?
Old Sep 29, 2015 | 12:01 PM
360_magnum's Avatar
360_magnum
We think we fixed it and the monitor went ready, just wasn't sure if that ment it was fixed.
Old Sep 29, 2015 | 05:00 PM
I think by 'monitor ready', the PCM now understands how to interpret which cylinder is misfiring, if any.....
Old Oct 7, 2015 | 02:41 PM
360_magnum's Avatar
360_magnum
its still running a little rough not sure if its missing or not, don't have any codes. can the throttle body cause a miss or rough idle if its dirty? if so why?
Old Oct 7, 2015 | 03:53 PM
If it isn't passing enough air, it can cause stalls, or low idle, but, that's about it. Rough idle is going to be fuel, or ignition.
Does it idle rough as soon as you start it up, or, does it take a couple minutes to show up?
Old Dec 27, 2015 | 04:16 PM
360_magnum's Avatar
360_magnum
So I got a p0300 p0302 p0305 p0307
Old Dec 27, 2015 | 05:10 PM
Is your plenum fixed? How many miles on the truck?
Old Dec 27, 2015 | 05:31 PM
360_magnum's Avatar
360_magnum
Doesn't have one. Air gap kit.
Old Dec 27, 2015 | 05:55 PM
Clear codes, reset the PCM, disconnect the front O2, and drive it for a couple days. (will set an O2 code.....) See if the misfires go away.
