4X4 vibration
Old Oct 23, 2015 | 01:09 PM
iconracing's Avatar
iconracing
Default 4X4 vibration
After replacing my clutch i have been feeling some vibrations at 65+mph in 2hi. I put my truck in 4hi today just to test it and i have a massive vibration at 40 mph. Any help is appreciated.
Old Oct 23, 2015 | 01:29 PM
All your u-joints tight? Bolts for the driveshafts tight? Rear u-joint seated all the way into the yoke? One or two piece driveshaft? (also, this is the second gen section, you really want to be in the first gen section.)
Welcome to DF!
Old Oct 23, 2015 | 02:18 PM
iconracing's Avatar
iconracing
Welcome to DF!
My cover photo is a gen 1 😀... I have checked all the u joints the seem ok no play in the shafts. I have a 1 piece drive shaft. When i did the clutch everything when back together smooth. Would this have anything to do with a t case saver?
Old Oct 23, 2015 | 02:49 PM
Maybe...... Wouldn't hurt to check it at least. Do you still have the vibration if you push in the clutch?
Old Oct 24, 2015 | 09:05 AM
iconracing's Avatar
iconracing
No vibrations in the clutch pedal... What are some other things i can check for?
Old Oct 24, 2015 | 11:23 AM
But does the vibration change when you push in the clutch? Or is it still pretty much the same?
Old Oct 24, 2015 | 04:12 PM
iconracing's Avatar
iconracing
It stays the same... small update i have a leaking front axel seal. I was almost a liter low on dif fluid. I need to take the diff cover off and inspect the gears
Old Oct 25, 2015 | 06:38 AM
iconracing's Avatar
iconracing
Gears look good no metal flakes... Im stumped... Should i replace the u joints?
Old Oct 25, 2015 | 08:56 AM
Khris1994's Avatar
Khris1994
Check them first. Push and pull on the driveshaft and see if you can move it. Front and rear. Also the axle u joints as well.
Old Oct 26, 2015 | 06:52 AM
iconracing's Avatar
iconracing
Well all u joints seem sound i will dc the front drive shaft when i get some time off... Also rotate the tires. Will keep posted
