Low heat.
Old Nov 29, 2015 | 02:50 PM
iowaman0322's Avatar
iowaman0322
Default Low heat.
I have a 1998 dodge ram. I just have a coolant flush and have changed the thermostat. The temp still only gets up to about 170. Would there still be air in system after a coolant flush?
Old Nov 29, 2015 | 05:53 PM
What temp stat did you install? If you put in a 195, and it ain't getting there, time for a new one.
Old Nov 29, 2015 | 06:34 PM
iowaman0322
It's a Staton. I boiled it and it opened
Old Nov 30, 2015 | 08:11 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
There might be a blockage in the cooling passages or even the heater core.
Old Nov 30, 2015 | 04:05 PM
What temp, not what brand.....
Old Dec 2, 2015 | 05:43 PM
iowaman0322
Temp 195
Old Dec 2, 2015 | 06:15 PM
Then either the stat is bad, or your gauge is lying.
Old Dec 5, 2015 | 04:24 PM
iowaman0322
Ok. The heat isn't very warm coming out of vents.
Old Dec 5, 2015 | 05:00 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Not to be a dick, but are you certain the thermostat wasn't installed upside down? It can happen to the best of us.
Old Dec 7, 2015 | 01:10 PM
iowaman0322
No. Doesn't fit other way
