Broken transfer case need help..
Old Dec 6, 2015 | 03:17 PM
iconracing's Avatar
iconracing
Default Broken transfer case need help..
1998 ram 1500 318
5 speed manuel (nv3500)
T case (231d)
Last night i when over a small bump and my t case shattered into 10 pieces. I am trying to replace the t case but the one i found on craisglist has a speed sensornear the id tag and mine didnt... My question is will this affect anything when i got to install it? My case is a 231d and so is the replacement.
Old Dec 6, 2015 | 03:21 PM
iconracing's Avatar
iconracing
The replacement i am trying to buy... Mote the speed sensor near id tag
This is what mine looked like
Old Dec 6, 2015 | 04:41 PM
dbbd1's Avatar
dbbd1
Prob out of a newer truck. Should be no problem but it would be if you needed one and didn't have it.
Old Dec 6, 2015 | 07:04 PM
Actually, its out of an older truck, and the shift pattern is going to be different, so, keep that in mind after the install.
Old Dec 6, 2015 | 08:14 PM
iconracing's Avatar
iconracing
Thanks guys
Old Dec 7, 2015 | 11:06 AM
iconracing's Avatar
iconracing
Last thing... This guy said his t case doesn't have a vacuum switch... Would that be a problem? And whats it used for?
Old Dec 7, 2015 | 10:18 PM
horatio102's Avatar
horatio102
It's used for engaging the front axle. So if you want your 4wd to work, then it's important - unless you permanently lock the front, swap the multi-piece shaft for a one piece, or get a 4x4posi-lok.
Old Dec 8, 2015 | 07:49 AM
Doesn't have a vacuum switch? What year truck did it come out of??
Old Dec 9, 2015 | 07:20 AM
iconracing's Avatar
iconracing
Same year as mine 98 thats why im puzzled
Old Dec 9, 2015 | 10:15 AM
Then it should have one, or, at least, a hole to screw one into. It isn't just plugged, is it?
