Belt tensioner??
Old Dec 25, 2015 | 07:07 PM
Bwally1996's Avatar
Bwally1996
Default Belt tensioner??
Pulled my alternator today (pain in my Burt didn't have a 9/32 socket for the tiny bolts on the back)
Got everything unbolted and didn't mess with the tensioner, spun it by hand and it sounds kinda rough so I was going to replace the bearings and pully, when I went to unbolt the pully the whole tensioner moved but never moved back. Should I just replace the whole piece? (it's like 60 bucks)
Or is it supposed to be like that
Old Dec 25, 2015 | 07:19 PM
I would. It's supposed to be spring loaded.
Old Dec 26, 2015 | 08:57 AM
Moparite's Avatar
Moparite
They have been know to stick, If you cant free it up replace it.
Old Dec 26, 2015 | 09:46 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
IIRC, the belt tensioner should be replaced ~75K miles. It's something most people don't bother to replace until the bearing freezes or grinds.
Old Dec 26, 2015 | 04:59 PM
Bwally1996's Avatar
Bwally1996
**** on it I'll replace it, should I go ahead and do the external regulator while I'm doing stuff? Lol
Old Dec 26, 2015 | 07:36 PM
ReadRam's Avatar
ReadRam
Are you having a voltage issue? The voltage is controlled through the PCM, I believe.
Old Dec 27, 2015 | 02:32 AM
Bwally1996's Avatar
Bwally1996
Pcm does control it, but I've heard it goes out
Old Dec 27, 2015 | 09:55 AM
It does, but, no point fixing something that isn't broke.
Old Dec 27, 2015 | 11:36 AM
Bwally1996's Avatar
Bwally1996
Preventitive maintenance. lol. But money I can spend on something else the truck needs
Still haven't figured out what that plug goes into. Maybe it goes to a brake controller?
Old Dec 27, 2015 | 12:55 PM
I would not call replacing a part that does not need to be replaced preventive maintenance. Lol.
