Motor swap help needed
Old Feb 14, 2016 | 08:47 PM
Burney's Avatar
Burney
Default Motor swap help needed
Alright fellas my old 97 318 failed me, so I found a wrecked 2000 ram with the same engine. My ? Is my intake calls for 2 temp sensors, and the 2000 doesn't. I'm wanting to use the intake of the newer truck. Is this possible? Is there one of those sensors I don't need? Thanks in advance
Old Feb 14, 2016 | 09:11 PM
Ham Bone's Avatar
Ham Bone
Just use your old intake. Theres no reason not to.
Old Feb 14, 2016 | 10:24 PM
94Beater's Avatar
94Beater
Or plug off the port you don't need
Old Feb 14, 2016 | 11:47 PM
Ham Bone's Avatar
Ham Bone
He needs two for his 97 pcm to work. 2000 only has one.
Old Feb 14, 2016 | 11:54 PM
dbbd1's Avatar
dbbd1
Could have one drilled and tapped.
Old Feb 15, 2016 | 10:10 AM
There isn't much difference between the two intakes..... could always do the kegger mod to your 97 manifold, then there wouldn't be any difference at all. (I think center divider is the main difference in any event. Fair bit of debate on just why it was omitted.)
Old Feb 18, 2016 | 02:15 PM
Burney's Avatar
Burney
Can I swap the PCM of the other truck? Or is that a whole mother can of worms?
Old Feb 18, 2016 | 03:15 PM
Ham Bone's Avatar
Ham Bone
Keep the 97 pcm. Use the old sensors too if none are busted. Remove crank sensor before installing 360 has they like to get broken moving around when it's on the lift.
Old Feb 19, 2016 | 11:25 AM
dapepper9's Avatar
dapepper9
Whole other can of worms because then you gotta deal with transmission and speed sensor too
HamBone posted good info
Old Feb 23, 2016 | 12:38 PM
Burney's Avatar
Burney
Decided to drill and tap the newer intake. Does anyone no off the top of their head what size I should use?
