Planning strong engine build from a 318, need tips!
Old Aug 8, 2016 | 04:45 PM
  #31
Toby Warford's Avatar
Toby Warford
You are leaving out the cost of fabricating mounts, driveshafts, adapting the wiring from one truck or the other to run the engine, and get correct info to the gauge cluster. (much more of an issue on the 98 and up trucks)
If you wanted to go to all that trouble, just drop a Hemi into it. Less work.
There's no mounts to fan, driveshafts ya, as for the wiring just a few adapters are needed. Like I said, its almost a direct swap. Don't speak of which you don't know. Its the same work and probably even less work then a hemi, and you still get a better engine then the hemi.
Old Aug 8, 2016 | 04:50 PM
  #32
Ham Bone's Avatar
Ham Bone
Well show me the adapters then? If that's easy you should be able to pull up a page basically telling us how to do this.
Not that I ever will......
Old Aug 8, 2016 | 05:54 PM
  #33
Toby Warford
Don't need adapters either.
http://ls1tech.com/forums/conversions-hybrids/1553358-world-s-easiest-5-3-swap-dodge-dakota.html
Mind you this is for a first gen Dakota, so imagine how.much easier it is in a full size truck.
Old Aug 8, 2016 | 07:12 PM
  #34
Adobedude's Avatar
Adobedude
6.0 vortec out of an ss silverado makes 345hp stock. Engines, tranny and tcase should run anywhere from 1500-2000. And will make more horsepower dollar for dallor then any magnum ever will.
I'm thinking you're on the wrong forum.
EDIT: Yep, I just checked. It say Dodge Forum, not Gay *** LS1 forum.
Old Aug 8, 2016 | 08:07 PM
  #35
Toby Warford
Lol butthurt much?
Old Aug 8, 2016 | 09:14 PM
  #36
The mounts need adapters. So, yes, there IS some fab work involved.
On the 97 and older trucks, sure, it wouldn't be that bad. However, on the 98 and newer trucks, ALL the gauges, including the friggin' gas gauge, go thru the CTM, which GM does NOT use, so, no gauges.....
I suggest you take some of your own advice.
